i've looked into a log manifold a great deal recently and am very confident i have nothing to worry about. as for twin scroll its no longer an issue for me to considerbrizanden wrote:logan exhaust pulses interfeering is not a myth.... Jeff go pick up the new issue of modified mag or read it at a store. Cause there is a 3-4 page article describing exatcly how a log and twin scroll works. So go edumacate yourself and then do what you think you should.
just cause log style or your building techniques work doesnt mean new greater things cant improve otherwise we would all be rocking huge big block v8s to make gobs of power.Logan76 wrote:Explain to me how the exhaust interfere's then? I want actual test results man. How does the exhaust pulse from one cyl flow against one from the other, if the others exhaust valve is closed?
Log manifolds are'nt the best manifold design ever, but they'll sure as hell work and you can make over 400hp on them.
p.s. I've educated myself in boosting cars without spending my life savings, I don't need a twin scroll equal length manifold to make 400hp, and neither does WC.
WC, sorry about last night, I fell alseep while talking with my girlfreind. I'll catch you on AIM tonight, I've got a birthday party for my girl to go to now.
I understand this, but that still does'nt discredit the log manifold. Your exhaust gasses have to flow alot further through an equal length tubular manifold, so do you really think that the turbulance in the log manifold is going to affect spool up time more than flowing 3x the distance?sommmatt wrote:Just because a cylinder's exhaust valve is closed doesn't mean there's not air flow coming from the cylinder that just fired going toward the turbo, which is going to run into the current cylinder firing, causing both pulses to gain turbulence.
It's not like a cylinder fires, all of the exhaust gas gets used up, and the next cylinder fires. Revving these engines out to 6, 7, 8, 9000 RPM, the engine is going to open and close exhaust valves faster than that air can be forced out through the bottle neck (turbo).
i never said he needed a twin scroll i mearly suggested he read and decide for himself what he wants to do. It was a good little article i learned something .Logan76 wrote:I agree' there are better manifolds out there, but you guy's act like you've never been on a tight budget before. Its either mig up your own stainless steel log manifold, or use an E-bay peice of trash and have it crack within two days. I love how everyone hates on the log manfiold but its proven itself over and over again.
if money is that tight, dont upgrade your turbocharging system. seriously.brizanden wrote:i never said he needed a twin scroll i mearly suggested he read and decide for himself what he wants to do. It was a good little article i learned something .
thats not knocking any one, but that just MAKES SENSE. my build's momentum has slowed due to my having to take a job i make significantly less at. it sucks, but im not going out trying to find the cheapest alternative, i just have resigned to the fact that it going to take longer cus i have to save up for parts.
no idea what you mean by thisDidderson wrote:Stop talking on aim and asking the same questions.
