Turtle Wax Ice
KayaVibration
Car: 2008 Altima 3.5 SE Coupe w/ Premium and Tech Packages
From Meguiars website... "After years of research into advanced polymer chemistry, Meguiar’s® has created a wax powered by Engineered Synthetic Polymer (ESP) technology. The result, NXT Generation Tech Wax®, is the most technologically advanced synthetic protectant for paint available for today’s modern finishes and clear coats. "But as I said earlier, the NXT wax is better for dark cars. It will kind of mute light colors. That being said, I bought some of the ICE wax at lunch to try it out.
I have the Meguiar's NXT and still have 1/2 the bottle left. It does work good, but I will be buying the ICE Liquid wax next , this based on how great the Ice Car Wash and Liquid Clay Bar work.
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
Has anybody tried the "Ultima Paint Guard Plus" products? $70 a bottle? Either it is revolutionary, or they are EXCELLENT marketing schemer's!
http://www.autopia-carcare.com/ult-1012-100.html
MisfitBrian
Car: 2008 Azure Blue Altima Coupe 2.5S
shift_mikey wrote:Has anybody tried the "Ultima Paint Guard Plus" products? $70 a bottle? Either it is revolutionary, or they are EXCELLENT marketing schemer's!
IIRC, Autopia is marketing this as their "house" brand & dropping Meguiars, Stoners & other vendors. I'm sure they can get a much better markup on these products since the retail won't be controlled by somebody else. I might look up on Autopia's forums to see if anyone has used it yet.
rfx45
I've seen that and contemplating on using it. Sure it removes swirls marks and gives a great shine, as they stated, but it also removes all wax and protectant already in the car and they don't recommend replacing polishing with these. That just doesn't seem worth the $70 price tag.
That brand is practically double the price from their competition and I'm just not sure how well it really works.
MisfitBrian
rfx45 wrote:I've seen that and contemplating on using it. Sure it removes swirls marks and gives a great shine, as they stated, but it also removes all wax and protectant already in the car and they don't recommend replacing polishing with these. That just doesn't seem worth the $70 price tag.
Where did you see that it removes wax? I saw where is says that other waxes "wash off" over a period of time. I do agree that $70 is pretty steep. I would need verification that this stuff really works before I bought it.
rfx45
MisfitBrian wrote:Where did you see that it removes wax? I saw where is says that other waxes "wash off" over a period of time. I do agree that $70 is pretty steep. I would need verification that this stuff really works before I bought it.
My fault, I was reading all the Ultima products last night and I must have gotten it all miexd up together. I got it confused with the Ultima Paint Prep Plus because in their FAQ for the Paint Guard Plus, they recommend using the Paint Prep Plus, which removes all waxes and paint sealant coatings.
dynot
Tonight I washed my car and then applied the Ice Polish. But I'm confused on all the ICE products.
What is the clay bar for and when do I use that? Does the polish replace the liquid wax and how often should I use the polish? If it doesn't replace the wax, when do I use the wax?
The Turtlewax website doesn't really give any advice on these products, only the benefits of using them.
rfx45
dynot wrote:Tonight I washed my car and then applied the Ice Polish. But I'm confused on all the ICE products.
The clay bar is used for taking grime and dirt and usually used before polishing as a prep.
The the steps usually go:
1) Wash - takes dirt off2) Polish - takes swirl and slight scratches off, also gives a good shine3) Wax - protect, also gives a good shine
It's not done for evey wash, usually every 2-3 months depending on the brand/quality used.
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
Just used the ICE wash for the first time and I have to say, it is great! I've been using Meguires Gold Class wash on my cars for the past 5 years or so and I think ICE is better. On the weekend, I'm going to try the ICE wax. I'm pretty sure it'll be just as good, if not better than the Gold Class wax. I guess I'm now an ICE convert.
MisfitBrian
I use a clar bar about 2 or 3 times a year to get all the grit that can get stuck in your paint. Use it after a thorough washing. Be sure to use the spray that comes with it to lubricate the surface or you will get clay streaks. The ICE polish is actually a polymer wax. True polish will smooth surface scratches & swirls. After using the ICE wax, I like the smooth application, but do not let it set for more than 5 minutes. I got a phone call after I had finished applying it. I had to get out my Porter Cable DA to get the wax off. It looks really nice, but I'm still not 100% sold on it yet. I might try an additional coat this weekend to see how it improves.
