turque steeings for arp hear studs
BQ.05.TD
Car: ca pulsar
can some one please tell me wat they are in ft/lb please:D
Modified by BQ.05.TD at 6:26 PM 8/14/2009
float_6969
Either you were drunk when you posted this or they talk funny in Australia.
BQ.05.TD
Car: ca pulsar
hahaha i seen it after i posted and was like wtf. i was just out of bed :Ddoes any one know ?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
float_6969 wrote:Either you were drunk when you posted this or they talk funny in Australia.
saw the thread name and was like
boost_boy
BQ.05.TD wrote:can some one please tell me wat they are in ft/lb please:D
For a metal or a stock composite gasket 80-87 lb/ft is more than enough.
Dee
float_6969
I thought you weren't supposed to tighten them more than 60 ft/lbs?
Also, plan on going back in there and re-tightening them after the motor has been brought up to normal operating temp and then cooled back down. I had 3 of mine loosen up, one to the point where it was only finger tight. I'm lucky I didn't warp the head.
BQ.05.TD
Car: ca pulsar
yer dee its a acl 3 layer one. its leaking along the exhaust side in 3 spots but it could also be tracking along the deck
will be making shore its not botteming out as well and might have to put washers under the arp ones
so a final torque setting is ? 80-87ft/lb ?
float_6969
Yea, Dee is right. I added as much ARP info as I could to the parts sticky.zerothread?id=114952
Buddyworm
Don't forget to double check everything you did once you sober up.
typhoonslippery
Buddyworm wrote:Don't forget to double check everything you did once you sober up.
lol
