Turns over but no start
carkook
Car has fuel and will turn over, the problem is it doesnt have spark. Replaced ignition coil, still no spark.
Where it says theres an ignition coil fuse there isnt one there??
These are right under the ignition coil on the wired going to it, what do they do?
Modified by carkook at 8:18 PM 6/15/2008
devildawg039
Car: 95 240sx se
replace that coil fuse that sould do it
carkook
Where is the coil fuse?
bret240sx
Car: Nissan 240sx 1992 coupe
Hey i have the same promblem as you do i hope someone can tell what to do..
NopzCEO
how do u know it has a spark
carkook
Alright if you dont know what your talking about dont post. It has power all the way to the clip that clips to the coil, then no powere coming from the coil. the coil is brand new. It DOESNT have spark. I think its the sensor with part number PRW-18z04. This is right next to the coil, if anyone can tell me what it is i would apreciate it. will have a picture in a second.
What is this? This the problem?
Modified by carkook at 10:18 PM 6/16/2008
carkook
NopzCEO wrote:how do u know it has a spark
DOESNT DOESNT DOESNT DOESNT DOESNT. SICK SKYLINE BRO hahahaha
bret240sx
hey your missing a IGN COIL fuse that will start your car funny you have a EGI fuse and i dont
bret240sx
got a question for you .. Do you have any light on the dash? is your seedometer or digimeter working ? beacuse i have the same promblem as you and my windows, my dash, my car dont work...
vancouverbc
Car: 1991 240sx
bret240sx wrote:hey your missing a IGN COIL fuse that will start your car funny you have a EGI fuse and i dont
RELAYS RELAYS . i dont have the ignition coil relay either so it is not a problem.
Ryans13se
Car: 1989 nissan 240sx
for some reason, I get the feeling its your sloenoid... my buddy was having a similar problem till he fixed his solenoid.
bret240sx
[QUOTE=Ryans13se]for some reason, I get the feeling its your sloenoid... my buddy was having a similar problem till he fixed his solenoid.[/QUOTE s
Were is the SOLENOID located plz show me a picture or be specific plz
thanks to how ever replies
carkook
Yes that would help, I thinkI found the problem. The ignition control module. But if thats not it i would like to know what your talking about.
carkook
bret240sx wrote:Hey i have the same promblem as you do i hope someone can tell what to do..
its taken a while, but I found it. The Crank Angle Position Sensor, located under your dist. rotar. If it goes bad or senses the crank in the wrong spot it doesnt let your Ignition Control Module tell the coil to make spark, resulting in no spark.. No start.
bret240sx
hey man that great news im glad you got it fix now did you change the distributer ? can you show me a pic of what you change. that will be awsome
vancouverbc
Car: 1991 240sx
bret240sx wrote:hey man that great news im glad you got it fix now did you change the distributer ? can you show me a pic of what you change. that will be awsome
your windows dont even work. find out what fuse is blown. if you dont have the egi relay, then you are never going to start the car. start your own thread. your problem is not the bloody distributor.
bret240sx
the
the egi relay is located beside the batery on the right fender? is it a black box ?
vancouverbc
Car: 1991 240sx
bret240sx wrote:the
no.
its in the relay box by the battery. your relay box should look like the above. you should have the two green relays which i guarantee you have.
check this relay box for blown fuses especially 75 amp fuse
joevanni
Car: NIssan 240sx
u tried to change the cam angle sensor it happen to me before and i replace the cam angle sensor and it crank back up
bret240sx
joevanni wrote:u tried to change the cam angle sensor it happen to me before and i replace the cam angle sensor and it crank back up
no i havent try it yet . what is the cam angle sensor and were is it located ?
vancouverbc
Car: 1991 240sx
i think we have a language barrier
bret240sx
vancouverbc wrote:
no.
i havent check them all yet but just EGI, and ACC and they look perfect . but using a light tester , it detects the EGI fuse as negative (no-light) and ACC is positive(light-on). now i dont know if it bad or not .
i still dont have light/power on my dash and windows
the coil do not have any electricity so there is no spark goin to the disttrubitor .ive tested with light tester on the plugs to the coil and distributer, and its been giving me (no-light) no electricity. i wounder if it possible if one of the wire is been cut/shorted or burn that were giving the electricity to the coil?
thanks for helping me out you guys
vancouverbc
Car: 1991 240sx
you not getting power to your windows. you have a blown fuse. ignore the 3 relays and check the fuses in the relay box. you probably can see where the fuse filement is melted. or test the fuses. only look in the relay box by the battery. look at everything except the 3 relays(two green and one grey)
bret240sx
all fuse a
all fuse are ok. ive check them all. i find this weird .. ive got to know were is my window/dash connected from . maybe there i can track the promblem .
bret240sx
good and bad new!
i found the problem for my dash and windows !!it was the 12v brown and a 12v blue fuse on the back of the relay box beside my kick panel (on the driver side (left leg). im happy ive got that done now
the bad new is.. well... the car dont start there is no spark from the ignition coil possibly another 12v fuse ? were could that be ?
thanks for the great help guys you guys are great really
vancouverbc
Car: 1991 240sx
bret240sx wrote:good and bad new!
http://img167.imageshack.us/my...8.jpg
i dont know much about the ignition circuit. power for the ignition coil comes from ignition switch with no fuse. do you measure voltage going to ignition coil. ignition coils basically never fail.
carkook
So I replaced the crank position sensor, inside the distributor. I still have the same problem, crank but no start. There is powere to the coil, but no spark.
bret240sx
no i dont have any voltage from the plug that goes on the ignition coil to power it up. the wire is black/red is the one that gives current to the coil if am correct. and also to give you some idea, there is no sign of voltage to the distributor plug ? even when boosting it up with another car still no spark
now my battery is goin low i need to juiced it up
carkook
quit thread jackin.
vancouverbc
Car: 1991 240sx
i assume your car cranks which means power is getting to ignition switch. you have to find out why the ignition switch is not sending power to black red wire at ignition coil. wire is cut or ignition swtich is bad or you are not reading the voltage right.
http://img522.imageshack.us/my...5.jpg
