Turns over but no start
bret240sx
Car: Nissan 240sx 1992 coupe
vancouverbc wrote:
i assume your car cranks which means power is getting to ignition switch. you have to find out why the ignition switch is not sending power to black red wire at ignition coil. wire is cut or ignition swtich is bad or you are not reading the voltage right.
http://img522.imageshack.us/my...5.jpg
HAHA MAN! your the man Vancouverbc !you made this day happier then befor
i found the power to the coil it was a tricky one it was not the same color as red-black to the ignition switch from the coil it was white-black so i follow the red/black wire from the coil then connected to the white/black wire that leads to the ignition switch power . Now its starts !!! but of course all that turn over but no start made my motor idle very slow like if it was gonna die on me sometime it would click on me when starting the car click co-start
thanks soo much for all of your cooperation if anybody has comme with the same promblem as i do id be glad to passed this down to the people ho will not strugle as i did
vancouverbc
Car: 1991 240sx
good stuff:)
