red240ne wrote:Yeh, my PS resovoir just kind of hangs around too.
klattr1 wrote:everything looks nice. I hope everything else goes well for you.Those moss colored s14s look so nice. Get a lip on that front bumper and it should cover up the intercooler sticking down.Are u having intercooler piping done?
Altiman94 wrote:checkered-member, there is no way you have over 2k into your motor. All you have is bolt ons and oyu dont even have a header...whats the deal?
Checkered-Member wrote:Plug wires--------55Spark Plugs-------51Intake-------------202Cat back----------349OBX headers-----24965mm TB--------200tranny cooler-----80oil cooler---------75filter relocation--60grounding kit-----41upgraded alternator--167upgraded battery--89Mobil 1 syntactic ($5 per quart X4 quarts X20 oil changes) = 400
Total: 2018
klattr1 wrote:all standard t3/t4's use 1/8 oil inlet.
I still think yall are crazy about the 1/4 oil inlet. I have confirmed that t3/t4's have 1/8" NPT oil inlets. I do not know where you are getting your information from or maybe you have a "special" turbo.Look here under turbo accessories...http://www.jgstools.com/turbo/index2.htmlbruinbear714 wrote:I confirmed with three different people over the last couple of weeks that my turbo has a 1/4" oil inlet.
klattr1 wrote:I still think yall are crazy about the 1/4 oil inlet. I have confirmed that t3/t4's have 1/8" NPT oil inlets. I do not know where you are getting your information from or maybe you have a "special" turbo.Look here under turbo accessories...http://www.jgstools.com/turbo/index2.html
sil80drifter wrote:Hey, cut your flange, the one that attaches to the manifold. Or it may crack. And if you haven't, enlarge the bolt holes in such a way that allows the flange to expand and shrink. I would hate to see this nice setup be a PIA because of the flange.
Otherwise, nice going
P.S: the FMIC is good for ungodly amounts of power, how much are you planning on running for WHP? Because if it's under 400, you may want a smaller one to avoid pressure drop.Remember: large size is good only relative to the application it's used for. Then again, your turbo looks like it could support the 400whp so maybe I'm just jealous of your nice FMIC
sil80
