SSSCA18DET »
https://forums.nicoclub.com/sssca18det-u17131.html
Wed Jun 02, 2004 2:25 pm
Even if the oil return line was blocked, this wont DAMAGE the turbo, it isn't good for the seals, but it isn't going to warrant a rebuild.
I'd suggest you get it looked at anyway, as they can clean it up for you in the process. If the oil is in the compressor cover, I'd suggest you check your return lines.
If it is on the turbine, that's bad.
