Turbo Rebuild Kits
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Ive searched, and I cant seem to find any T25 or otherwise turbo rebuild kits through any of our sposors, my trubo is smoking pretty bad now and Ive had a spare T25 with bad seals sitting here for weeks, I just dont know where to find a good rebuild kit. Any help would be greatly appreciated
ThanksIan
IanS
bump
Im doin a motor swap on a suby so Im gonna have spare money for the kit.
karmakaze
Car: 98 240sx SE
SideWays=smiles wrote:bump
not all turbos can be rebuilt. but you can usually order a new chra. take it to a machine shop and they will be able to tell you. if you can't find one that services turbos, call your local diesel mechanic and he will be able to refer you to one.
IanS
stupid question, how should I get the turbine wheels off, without bending the shaft?
AmoebAssassin
Car: 1991 Base fastback 5spd, black
The turbine wheel is part of the shaft. If you have already removed your compressor wheel, your exhaust and compressor housings, and any visible c-clips and bearings and your shaft is still captured in the CHRA, you have a non-user-rebuildable ball bearing CHRA and you need to order a new CHRA.
IanS
its a journal bearing Garret T25, and Im wondering how to get the nut off the exhaust side, Ive heard that putting another wrench on the turbine can damage the shaft.
AmoebAssassin
There is no nut on the exhaust side! The turbine wheel does NOT separate from the shaft. Only the compressor wheel separates from the shaft -- the turbine wheel is cast along with the shaft, and they are the same piece!
IanS
hahaha, my mind was thinking one thing my hands were typing another, i get what you mean but I still need to get the nut off the compressor, should I just use 2 wrenches or is there a better way to do it
AmoebAssassin
No, use two wrenches and careful application of force.
IanS
just like to mention, the nut was reverse threaded, my buddy caught me right befor I started cranking on it, the wheels are now at the shop being beed blasted and balanced, rebuild kit should be in on wednesday
ho1ywars
whats a chra?
ho1ywars
IanS
its the turbos center section
TheKryptKeeper
Rather than make a new thread, I would rather drag this up from the depths of oblivion. Where did you get your rebuild kit from? I see them all the time on ebay, but I'm not sure about them. I have a T25 with tons of shaft play (no housing damage on the cursory inspection). However, the turbo is clean. There is very little carbon on the turbine and the compressor is beautiful.
Also, is there a way that I can balence it on my own? I'm in the middle of New Mexico, and there isn't much of a performance market out here.
Thanks,Krypt
TheKryptKeeper
Bump.
IanS
TheKryptKeeper wrote:Rather than make a new thread, I would rather drag this up from the depths of oblivion. Where did you get your rebuild kit from? I see them all the time on ebay, but I'm not sure about them. I have a T25 with tons of shaft play (no housing damage on the cursory inspection). However, the turbo is clean. There is very little carbon on the turbine and the compressor is beautiful.
Thanks,Krypt
any good diesel repair shop should be able to balance the wheels and they can order the kit for you, Ive never been to a performance shop that could do balancing, at least not in my area,
