TURBO QUESTION
tebsie
Car: 1994 180sx
Recently my turbo started making a weird shreiking noise that only happens when i hit full boost. It used to just make the normal sound of a turbo spooling and still does until full boost, its quite loud and doesnt sound healthy but there is no loss of power or smoke from the exhaust. im baffled and any help is greatly appreciated.
I have a 94 180sx thats stock except for filter and cat-back exhaust
adrianfromthecastle
Car: 1992 Nissan 240sx
check your turbo lines... i'm thinking theyre fried or something. notice a puddle of coolant sitting under your car?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
yah, sounds like your turbo is about to take a crap
adrianfromthecastle
^^ still can be saved... just fix your lines before it you turbo blows... switch to ss lines.
tebsie
Car: 1994 180sx
Thanks guys i'll check the lines in the morning
drftsx
Car: 90 240sx(sr)
i thikin im kinda having a similar problem. my turbos not so loud but it leaks oil. is it a similar problem?
karmakaze
Car: 98 240sx SE
drftsx wrote:i thikin im kinda having a similar problem. my turbos not so loud but it leaks oil. is it a similar problem?
leaks oil in the inside or on the outside?
IanS
karmakaze wrote:leaks oil in the inside or on the outside?
and if it leaks on the inside, does it lead into the exhaust or intake.
