Mista Sparkoh »
https://forums.nicoclub.com/mista-sparkoh-u40084.html
Thu Apr 05, 2007 3:43 am
Hey guys, I haven't been on this forum for a while and with my current problem I hope you guys can give me some inputI've searched for it but couldn't find anything related to my situation so here goes
I picked up my car recently from a shop to get my gauges installed. I have the SR with the T25 turbo running on the HKS adjustable actuator. Before I dropped the car off, I was able to boosted properly (about 0.7-0.8 BAR, could hear compression surge, and had good response)After I picked up my car, I test drove it to see if everything is fine, which isn't.The boost gauge reads vacuum and when I punch the thottle, it takes REAL long to spool the turbo but I can't hit high boost like I used to. I popped the hood and realized that the WG arm is disconnected. So I re-attached it back but I'm still getting the same problem. Here is a list of symptoms I'm getting (exactly like the ones when my WG arm was detached):-Turbo is struggling to spool-Can't reach high boost numbers like I used to (maybe like 5 psi before I have to shift)-BOV doesn't sound-Don't hear compression surge when I lift the throttle
I want to know if it's a common problem so I can fix it before I take it back to the shop.
