Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Sun Jan 18, 2004 10:51 am
Several weeks ago I put my newly rebuilt motor in the car (an S13) which went relatively easily, the only issue was that it did NOT want to settle onto the passenger side mount but this was finally fixed. Since then I recieved my new manifold, IAP's latest version. It has been verified that this newest version fit onto Marc's car (an S14) without issue and both of our manifolds were made with the same jig. The problem is that the outlet of the turbine is directly in front of the brake lines coming off the inside of the master cylinder. Here are two pictures: I have done several things to address this problem, the first of which was to call Marc and verify that the manifold was working fine on other cars to remove that from the equation. The second thing I did was have Megaseth03 with his stock, never removed engine come over to verify I had the mounts set up right, we both agreed that the motor looked like it was sitting a good bit higher in the front than his and did not look like it was aligned longitudinally with the rest of the car. It was at this point that I figured out the engine mounts could be slid up and down, both of them were almost all the way down in the slots as well. After I figured out that the brackets were on the correct sides, I tried lifting the drivers side of the engine as high in the mount slot as possible while dropping the passenger side as low as possible. This was the point the pictures were taken at. This did nothing to solve the problem of the future downpipe running right THROUGH the brake lines, only made the engine sit even higher, albeit less tilted than before. It's hard to see the problem from the pictures but hopefully you understand what I mean. I'm at my wits end on this issue and have now discussed it with 3 knowledgeable people who have no idea how to solve the problem. I see my only choices currently as either modifying or fabricating new motor mounts that put the damned thing in the RIGHT place (shifted towards the passenger side about 2 inches), or beating it with a 20 lb. sledge hammer until I feel vindicated. Can anyone else offer any other suggestions of places to look for a solution? Also, it should be noted that the transmission is a 95 transmission, the motor is a 92 motor, and the car is a 91 chassis. The transmission mount from a 91 transmission mounted up perfectly as well.
