What if you are li mited by pump gas tune, injection systems aside. The additional latent heat of compression, along with the added cylinder pressure from the rise in boost both contribute to aiding detonation.WDRacing wrote:Ok, lets talk about making more power. You two guys choose the $1200 manifold. Which is awsome, I don't disagree with that at all. I choose to add a few more lbs of boost instead. Lets say we both end up with the same exact WHP and Torque output cause I'll only add enough boost to get the same numbers.
If both motors are putting out the same amount of power the stress level will be very close, in fact I don't think it can be measured.
Power output is power output. The better manifold may spool quicker by a few hundred RPM, but that is the only thing I can see being of any real advantage here.
No it's not. You are not forcing extra pressure into the engine, which is what a turbo does (obviously).IHE helps reduce the pumping losses of an engine.nissanfanatic wrote:So IHE put more stress on the engine? Same principle.
I'm not saying you aren't allowed to, I'm saying that it's not like you can't do the same with the manifold on the car.WDRacing wrote:You definitly can not call more boost a band-aid fix.
For the additional $900 I have left over from buying the JGS instead of the Full-Race, I can easily make up 60WHP without adding nitrous...hell, a simple $60 water injection system will kill any latent heat that raising the boost causes. Can't taise the boost, then add more timing. You can't say I'm not allowed to tune the car, thats a bad comparison. I'm saying I can spend my money in different places and get more gains. Your saying the equal length header is a better route. I disagree...
WD
Also the same point behind tubular manifolds. What I said was slight sarcasm/response to more boost for more power. Just in case you were taking it as me saying that IHE actually does put more stress on the engine.lol Like an interrogative answer more or less...SSS wrote:
Somewhat.hysteria wrote:i think though that wd makes a good point because let's look at a completely stock ka24de with a bolt on turbo...now whether i choose to get my power from having the most efficient setup out there and it runs perfectly or one that will require more boost to make the same numbers the engine will stand up to comparable numbers, not comparable boost...if that doesn't make sense i'll use an example:for the good quality kit lets take phat ka-t kit as an example, and then something a little bit lower quality (not quite as low as ssac, but something like that, maybe a pieced together kit that isn't quite as good)... now let's say for comparisons sake phat ka-t's kit takes about 11 psi to make 350+ hp.... to get the same numbers from the other kit it will take probably 15 psi or maybe more....now neglecting power/torque numbers lets say i then push the quality kits boost numbers up to the same as the other engine (15+psi)... well then the reliability of the engine with the higher quality kit comes into play as the engine is reaching it's power limitations based on experiences people have had with ring lands and what not breaking in the engine... the other engine will not be making the same power but it's not going to die because they are not doing the same thing... stress is different here, but when the power levels were the same the stresses were ~the same...
does that makes sense?
Even so the man who makes 350 at 10psi wins over the man with 350 at 15psi becuse it take less time and effort to make 10psi. So the mani would win in more then one way. Not only will it spool you faster but you require less boost to hit the same #'s making the boost seem that much faster. Anyone can be a dyno queen, what you want is good power across a large range.hysteria wrote:i think though that wd makes a good point because let's look at a completely stock ka24de with a bolt on turbo...now whether i choose to get my power from having the most efficient setup out there and it runs perfectly or one that will require more boost to make the same numbers the engine will stand up to comparable numbers, not comparable boost...if that doesn't make sense i'll use an example:for the good quality kit lets take phat ka-t kit as an example, and then something a little bit lower quality (not quite as low as ssac, but something like that, maybe a pieced together kit that isn't quite as good)... now let's say for comparisons sake phat ka-t's kit takes about 11 psi to make 350+ hp.... to get the same numbers from the other kit it will take probably 15 psi or maybe more....now neglecting power/torque numbers lets say i then push the quality kits boost numbers up to the same as the other engine (15+psi)... well then the reliability of the engine with the higher quality kit comes into play as the engine is reaching it's power limitations based on experiences people have had with ring lands and what not breaking in the engine... the other engine will not be making the same power but it's not going to die because they are not doing the same thing... stress is different here, but when the power levels were the same the stresses were ~the same...
