The fee to get an EO# from the CA ARB is around 150$ (that was just a phone conversation, so he may have been indicating only one aspect of a larger fee). The big dollars come in during testing.
What I mostly know. These are not set in stone, but should be mostly correct.
The kit must not be user adjustable from the listed specs. So no variable boost controllers, fuel maps, AFC's, or anything else that would allow the user to make changes. If a user adds this afterwards, the user violates smog even if it does not affect the sniffer results.
The kit must not make the car worse than the "baseline" for smog results. The trick here is that the ARB offers a number of different ways to create a "baseline" for a given car. This gives significant flexibility and a little wiggle space in regards to smog output. In addition older models (S13) have a higher baseline anyway. My goal was to produce an S13 kit seeing as how thats what I own.
The kit must not remove factory smog controls. This is a kinda/sorta rule. You can move parts around, but when you do, the re-location becomes part of the EO# and a description of the re-location pops up on the smog computer when they scan the EO# barcode. An example would be re-locating the EGR farther down the pipe to catch cooler exaust. Another would be re-location of the MAF and airbox, or movement of the O2 sensor to put it in the right heatrange on the exaust.
All kit parts must be listed with a description of the components. In other words, the type of MAF used, the model of turbo, type of O2 sensor (if you change it), PSI setpoint of the kit, type of injectors, timing changes, fuel curve changes (FMU, ECU, piggyback), model of any FMU, ECU. You get the idea. The reason for this is to pass the visual inspection of a smog test. Also, if it is re-timed, the tech testing has to know what the base timing is supposed to be if it varies from factory timing.
Some other small sundry things which I may, but most likely do not yet know about.
The kicker is that once you get a kit designed and all the parts arranged, you must go to an ARB research facility or one liscenced by the ARB for testing. I expect they will do cold-start, idle, cruising, dyno, and part-throttle testing. As for the facilities approach, I don't entirely know since I haven't gotten that far yet. The easiest way may be to bring a car, get a baseline smog result, then add the kit and go from there. If any problems come up, the ARB does provide an on-call engineer to help out for free. Neat, huh? The big problem.... the ARB man said costs are expected to be from 5000 to 10000$ for the certification testing. This does not include what you paid for your parts. Additionally, the ARB may ask for a kit of its own (that you supply for free at your own cost) to test on a car of their choice based on the model you are making the kit for. Usually, if you get a "worst case scenario" car (high mileage, weak cat) to pass at the reasearch facility, there is nothing the ARB can find that will cause any hiccups. The ARB man even said that.
As far as time-to-certify... I have no idea. I imagine it depends on where you go and who you talk to. Considering that the ARB answered my call on the second ring and talked to me for more than 30 minutes and was very polite and helpful, either I got lucky, or they really are there to make things go fast and easy for you. From there, you pick the right testing facility and maybe things go fast?
So there. Was that a worthwhile read, or do you want your 5 minutes back?
