turbo kit comparison
toki
this is really a more question of "how can i waste the least money" because either way you could do it for less building your own now wanting to run more boost than what they provide for out of the box. so you see, build your own, lazy.
:D no disrespect intended btw
TrunkMonkey
Car: 2000 Lincoln Navigator
toki wrote:this is really a more question of "how can i waste the least money" because either way you could do it for less building your own now wanting to run more boost than what they provide for out of the box. so you see, build your own, lazy.
actually, even though some prices have been tossed around, this thread has nothing to do with which kit is cheaper. it has to do with which kit will perform better at 12 psi. building your own is not an option.
please try to keep this on topic.
-demetrius
andrave
Car: 1989 Nissan 240SX Coupe
why do you need top mount 550's for ka24de?
aleph1
Car: 1990 240SX hatch MODS: class.
andrave wrote:why do you need top mount 550's for ka24de?
huh? i dont get the question.
TrunkMonkey
the greddy kit comes with top feed injectors and fuel rail. you would need to find top feed 550s to upgrade.
-demetrius
andrave
I thought the greddy kit came with stock sr20 injectors or something similar. hmph.
aleph1
andrave wrote:I thought the greddy kit came with stock sr20 injectors or something similar. hmph.
It does, 370cc ones. He saying that to make 12psi, youd prolly want to get 550cc ones which would be fairly cheap as they would be top feed.
s14db
Car: 1998 240sx
My understanding is that the Stock pistons suck and after getting into that much boost one of them will fail or at least the ring will fail. I think Race Engineering(http://www.raceeng.com) has some good parts.
andrave
s14db wrote:My understanding is that the Stock pistons suck and after getting into that much boost one of them will fail or at least the ring will fail. I think Race Engineering(http://www.raceeng.com) has some good parts.
Original post:
Quote »ok bear with me..just a quick comparison on a mildly ported and polished motor, ross forged pistons[/quote]
hmmm
also, about the injectors:I thought he was saying he NEEDED 550 cc's like for some reason the greddy kit came with a top mount rail. I was just confused.
s14db
Car: 1998 240sx
The greddy kit comes with top mount 550cc's and a blue top mount rail. It's the blue bar you see in the pics.
Structure240sx
the greddy kit comes with top feed 370cc injectors. stock SR injectors are side feed 370cc
alan-n
Car: 95 240sx
Another kit to consider is the import-autoperformance.com kit. It retails for $3800 including cost of shipping.
Here it is on my car, did all the installation work myself and fitment has been excellent. You can customize the kit to your specs or substitute parts where needed:
http://www.cardomain.com/id/cvn0605
bruinbear714
Well, if we're ignoring costs, then I would go with the NSPORT kit + some sort of piggyback + bigger injectors + a fuel rail.
But since cost is a factor in the real world, I would go with the Greddy kit + front mount ic and pipings + support tool + harnesses, which can all be had for under $4000. The idea of having your car tuned over a weekend of your choice sounds a lot better than waiting forever for JWT to remap your ecu with a generic map. Let's not forget that the emanage also has a 16x16 ignition map.
That's the route I'm taking currently, however, I'm using the emanage and setting that up for a z32 maf and 370cc injectors first on a n/a ka.
90lkn4swp
Car: putting rounds down range / and gettin back home so i can drive again
Personally i love the ceramic coated equal length 4-1 autoperformance includes with the kit.there are a few things i would switch out but other than that id have to say go with the A/P kit anyone have any thoughts on the vortech fmu or aeromotive RRFPR? as of now im seriously thinking of going with this kit
mean green s14
Car: driving like a retard
sorry to tell ya but the e-manage that comes with the greddy kit is pre programmed and you need a pasword to change it and make adjustents.
bruinbear714
mean green s14 wrote:sorry to tell ya but the e-manage that comes with the greddy kit is pre programmed and you need a pasword to change it and make adjustents.
I know that... the whole point of moving away from a JWT ecu setup is so that I can get away from a generic too-rich fuel map and tune the thing myself. Each car has its unique fuel map.. so while a generic map may work, it may not be optimal.
And besides, I already have an emanage on order along with their overpriced cd so that pre-programmed unit that comes with the kit will be sold.
j-z
Car: 95 240sx
can someone give me some websites of where youre finding all these kits at. i would like to see how theyre setup and what all they come with. thanks
mean green s14
