What turbo shield? A piece of steel with bolt holes in it? Entirely not worth it. It will stop some radiant heat, up until the steel itself becomes heat-soaked, and gives off it's own radiant heat.rseabrooke wrote:Yea I am going to order the Turbo shield from BD but I was thinking I might need to do the other stuff. Loosing brakes while on the highway is really not cool!!
I have been in contact with Tim Thompson at atpwrap.com and while not exactly cheap at $275 for the turbine heatshield, you're going to be hard pressed to find any other options that are of higher quality. Plus, I like the idea that Ryan has gone with...attack the problem at it's source, don't bag up everything else in the vicinity.klattr1 wrote:with my ATPwrap.com inconel heatshield, i havent had to worry about master cylinder resevoir melting or protecting it from doing so.
i figured, instead of wrapping the thing that could have been damage, i would wrap the original source (the turbine) and keep the heat inside of there.
its definitely not cheap, but i imagine the Thermo-Tec heat-blanket that Duy or Brian (NX95240) uses would also work just fine.
thats the only thing that is coated, covered, wrapped or whatever. my old F-Max manifold and downpipe was ceramic coated as well so i imagine that does help as well, but no major need to ceramic coat the turbine with the inconel heatshield.savatoge wrote:Ryan, I'm curious...did you wrap your downpipe or have any type of thermal coating applied to it? And I see you have not bagged your master cyliner/brake reservoir...did you have to wrap anything else, or was the iconel heatshield the only component that you applied to fight off heat?
inconel is more of rare metal which is used in high temp. spots in nuclear powerplants and even on NASA projects. it is 3000 deg. farenheit resistant.turtl631 wrote:Holy balls, 275?? WHY??!?
what r u talkin about hitman?AZhitman wrote:...then get them on a REAL forum where people will buy their stuff!
well the heat shield i have fits on a Precision SC61 which is just like most ford style 5 bolt turbines. im not sure if it would fit on the turbine housings that BD uses.chandler wrote:two things, first will the wrap that klattr uses fit on the boost designs stage one kit
you know since you got s13, you may do a self made ram air thing on both sides and direct it to the engine bay.rseabrooke wrote:I am thinking the same thing. Why is it that the EVO`s and WRX have vented hoods? There has to be a reason that both companies went with a vented hood besides looks. I think they are using it to help keep temp down since they have warranties on these cars and they have to last more then a year.
