Turbo guys!!
Blast down the 1320? Love the 1/8 mile action? Here's your forum.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Just curious to hear what turbo you guys are running that makes good power and spools quick.
What kind of numbers are you guys turning also?
I currently have the best of 7.80@91 in the 1/8th with 1.6 60' without launch control. Rb25det, All internal mods, Stock T28 turbo and manifold.
Im planning to go back to the track this friday and see what kind of 60's I can get with launch control.
Im looking into the gt32 or Holset, But I want something thats gonna work with my setup. Remember Im an 1/8th mile car. I don't have 1/4 mile around me.
S14toRPS13
Damn, 7.80 in the 1/8th is pretty fast. How much are you boosting?
rb25drag
I did the 7.80 on 10lbs of boost. Im running 13 now. Going back Friday night to see if I can break the 7.50 mark!!
240_SeX
Car: 1992 240SX SE
What are you using for an EMS, if you have something with 2 step and anti-lag you can run a bigger turbo and not have to worry as much about lag. Also is this a DD or a track only car.
BTWnice 60' what do you have for wheels/tires?
rb25drag
The only engine management I have is a SAFCII and thats so I can tune my fuel curves for the z32 MAF I put on. Im planning on switching to propane within the year so I can run more boost and compression. Plus I don't have to buy 1500$ engine management units to tune with.
I just installed a Gizzmo launch control, I have only used it 1 time and I broke my driveshaft. I have a new 1 piece steel shaft from shaftmasters I just installed.
I was running 17x8 F&R with 26x11.50x17 MT ET streets. But I have a new wheel combo, I traded my 17's to MeanGreenS13 for his Draglites. 15x4's up front and 15x8's in the rear. With this wheel combo I should pick up a tenth in the 1/8th, also should bring down that 60" a little more cause I was bogging with the 17's.
The car is not a DD, I do drive it on the weekends sometimes. Its mostly just a track car. I can't keep my foot out of it so its safer for me to keep it on the track
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
Garrett T3 ( z31) 6-8 psi ( boost leak)
stock suspension stock wheels
13.7 @ 104 mph
Holset h1c 8.50psi
JIC FLT-A1's 17in wheels with RT-615's
14.2 @ 100mph
Dynoed 204hp at 5500 rpms 3rd gear pull
240_SeX
Car: 1992 240SX SE
Biggamehit wrote:Garrett T3 ( z31) 6-8 psi ( boost leak)
13.7 @ 104 mph
Holset h1c 8.50psi
14.2 @ 100mph
...wow
why 3rd gear on the dyno??
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
they normally do 3rd and 4th unless the owners says other wise... after the 3rd gear pull, my car started missing..... im having either an Knock Sensor issue and or CAS. ill fix it.
240_SeX
Car: 1992 240SX SE
a 3rd gear pull will give inaccurate numbers, you hav to do your pull in the gear closest to 1:1 on the KA and SR trans its 4th. That may be why you got such low numbers, an miss could also be at fault
USsil80
a 1.6 60' is really good... you not going to top that much... you are into the 12 with that and damn that is good
rb25drag
USsil80 wrote:a 1.6 60' is really good... you not going to top that much... you are into the 12 with that and damn that is good
No doubt the 60's are good. But it still has more for sure. Cause pulling those 60's it is bogging.
Im still waiting on my ARP wheel studs so I can go back and test some more. But there on back order. So I dunno when Im going to get back.
I think it has a 1.4-1.5 60' and a 7.50 1/8th mile in it.
USsil80
have you tried to get the nismo whedels studs..
rb25drag
Nismo doesn't make them as long as i need. I just got a set of Draglite Mustang wheels so it takes 3.5"-4.00" Long studs.
If there not here this week im canceling my order and doing something else.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yea im aware of that... however it didn't start missing until after the run. not during. ill go there again on a cooler day. i know the car is much stronger than that...
kzoosho
Car: Turboed 1997 Nissan Maxima SE
Im running a turbonetics 60-1 @ 9psi and ran a best of 13.2 @119.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
RB25drag, I googled Spring city TN and you are 3 hrs. from me. I am just north of Clarksville TN. We need to get together at Nicofest in Nashville July 26th and 27th. They are having heads up 1/8th mile drag racing at Nashville Speedway. zeroforum?id=240I hear they have a nice track set up on pit road and there should be some really fast imports for this area. We should be 1 hell of a race. Our times are very close. It should be a half way point for both of us at about 1.5 hour drive. Hit me up if you want a good race with another S13. [email protected] you ever want to see what she's got in the 1/4 we could meet in Bowling Green at beachbend raceway. [URL]http://www.beechbend.com/Dragstrip.htm[/URL]It will be a 3 hour drive gor you, you might be closer to Bristol??
kentuckyslider
As for turbo for your RB25 I would go with this............http://www.atpturbo.com/Mercha...e=GRTThe RB will spool this turbo much faster than the SR and it will easily put you over 500whp with the right injectors. That is as large as you will get with the stock bottom mount mani, if you want over 550whp you will have to go top mount and GT35R or larger turbo. You're looking at spending over $4000 to go top mount and you could go with the GT3076 with internal gate and keep your stock mani & down pipe for $2000 with tune and still make 500whp. You are close to these guys and they just got a new dyno http://www.jgycustoms.com/!!!!
rb25drag
I have heard alot about the Nashville race, Im about 2.5 hrs away from the track. I would come, but Im not sure how my setup is going to be. The last 2 times I been to the track I have broke on the 1st pass. Im going to I-40 Dragway in 2 weeks July 11th to tune my car. I have changed alot on the setup since I been last. I have a new custom driveshaft made by shaftmasters, New wheel combination and i have upped the boost from 10lbs to 15lbs.
Im about 4hrs from Bristol, Which Is a long ways for me to go and break on the first pass LOL. But when I get the setup right and reliable Im going to go run a 1/4 mile track and see if I can't hit some 10's.
As for the turbo setup. I can build my own manifold, Not a problem, But im going Propane probably over the winter. I have a close friend experimenting a bunch with it on some turbo cars. That will get me out of the 3000$ worth of Crap to tune it on Gas, Plus propane is 110 octain.
I would like to meet you sometime. Possibly a weekend get together BBQ ETC!!
How far are you from Crossville?
kentuckyslider
breaking axels or u joints? I have made over 100 passes with MT drag radials and never broke anything. If you feather the clutch and don't drop it you shouldn't break.
kentuckyslider
I am 3 hours from Crossville and you are 3 hours from beach bend in bowling green Kentucky. NHRA 1/4 mile track, that is where we need to meet!! Your tires are much more grippy than mine maybe to much. What rear end do you have? 26X11.5" ET streets, how much do your wheels and tires weigh?
rb25drag
I broke the axles twice and the U-Joints 3 times.
I know I have the U-Joints fixed, The axles are still the stock r200, I can't afford to get the better stuff right now. but I will soon. Problem was I ran an 8 inch Drag slick, was fine till 1/2 track and it would start getting stupid sideways with me, It was just spinning 3rd gear. So I upgraded to the 11.5 Et street, I got 2 decent passes on them, 1.67 60' 7.80 Then did a 1.70 60' and a 7.87, Thought I had found a good combination until the next pass, Then i just broke both axles and never moved off the line.
I Pre-load the Drive tran before I launch, I make sure I have No slack and I don't just drop it, Its really hard to slip my clutch, Running a twin plate Cusco exedy Stage IV, Its usually all or nothing.
I have recently traded my old wheel setup for a new set of Drag Lites.
My old wheels weighed in at like 175 for all 4 with tires.
These drag lites weigh in around 100LBS total all 4 with tires.
So I have shedded a few pounds, Also went from a 17 inch to a 15 inch, I don't think ill be as harsh on the drive tran with this combo.
Will see in a week what happens.
Here is a pics of the ride now:
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
i almost miss those wheels
kentuckyslider
MeanGreenS13, where did you get the drag lites in 4x114.3? I haven't looked alot, but all I seem to find is 4x100?? What tires are you running on the back of those?
kentuckyslider
I didn't know what kind of clutch you had, now it all adds up. 11.5" wrinkle wall and a twin disc, you will explode something with the 2 step. I am going 26x8.5 ET drag maybe on some drag lites if you can hook me up with a link for the wheels in 4x114.3. I ran a 1.72 60' with the same size drag radials. I have seen several SR's run 1.5 60' with the 26x8.5" wrinkle walls with a 2 step. That's all I need to break below 7.5 in the 1/8th.
rb25drag
MeanGreenS13 wrote:i almost miss those wheels
Hey man, you need to make a road trip when you get yours all fixed up and come check everything out.
I have a buddy that loves your ca18. Too bad you live so far away!!
I see the 4 lug drag lites for sale all the time on ebay, Prob your best bet.
MeanGreenS13
if he likes it so much... he should buy it... i need it gone, need a truck badly right now, only asking 6500, once its back running, 7000 lol thatll be in about a WEEK hahaha
MeanGreenS13
i bought the draglites from JEGS...
rb25drag
MeanGreenS13 wrote:if he likes it so much... he should buy it... i need it gone, need a truck badly right now, only asking 6500, once its back running, 7000 lol thatll be in about a WEEK hahaha
Hey man Ill def let the word out. Thats a killer price on your setup. I know you prob have Double that in it.
MeanGreenS13
pretty damn close... SC61 is gonna bring lots of joy to SR haters all over the world =P
kentuckyslider
MeanGreenS13 wrote:i bought the draglites from JEGS...
It looks like they're unilug in the pics. When I contacted Jegs they didn't have a clue? Guess I talked to the wrong salesman, he acted like they only came in 4x100?? Thanx
Return to “Nissan Drag Racing Forum”
