Turbo guys!!
Blast down the 1320? Love the 1/8 mile action? Here's your forum.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
they are universal 4x100 and 4x114.3 on the same wheel.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
What fr. width and rear backspacing did you get? http://www.jegs.com/p/Weld+Rac...36673
kentuckyslider
I don't know if the skinnys will fit over my Z32 30mm calipers???
kentuckyslider
" I have made over 100 passes with MT drag radials and never broke anything. If you feather the clutch and don't drop it you shouldn't break. "
Dropped 2nd gear in my car today. With street tires on. That's what i get for talkin sh#@!!! Doing the KA/SR bellhousing swap this weekend instead of installing the 2 step.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I have never just Dumped the clutch, I know for sure it will break LOL, I think the Rb makes a little more tq than the Sr so thats prob the launching difference between breaking and not.
That totally sucks about your 2nd gear!! Are you sure the ka will hold up? They seem strong, But not 300HP strong.
If I ever break the rb25 trans im converting it to a turbo 350 Automatic with a Big stall.
rb25drag
Well went to the track last night. Was not happy, Car ran great, It pulled harder up top than ever before. But the track was Extremely crappy. Couldn't launch to save my life without spinning. Took my tires all the way down to 8psi, It hooked a little better but was still spinning pretty hard. Ran the best of 8.06 @ 87 with a 1.7 60'
It was also 90 degree's outside.
kzoosho
Car: Turboed 1997 Nissan Maxima SE
I went to the track on the 11th and well it didnt stay together for a single run. I ran a 13.8@101 and blew a coupler off my charge pipe right after the 1/8th. I have a short vid of the run.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
hahah i have done that on the track before also... first thought was.... On No not another ****ing KA......
rb25drag
Well I went back out to the track friday with a different suspension setup, It seemed to work very well, But I think I killed my coils in the process, The car doesn't make any power up top now, Won't rev over 5,000 without a misfire and dropping a cylinder. I guess my 2 step beat them to there grave.
MeanGreenS13- I got 15 passes out of the rear tires. They are now BALD lol, I don't think I will use BFG drag radials any more, They didn't seem to wanna hook and I burned threw them Quickly. I think im going to go back with a MT Et Street.
MeanGreenS13
scott i know guys in 1500hp domesics dead hooking on them. How long of a burnout are you doing? thats the key on bfgs
rb25drag
Man I tried every kind of burnout you could think of. I set in the burnout box for a good 5-10 sec before rolling threw the lights with a pro stock burnout!! Hell I had the track So smokey we had to wait for it to clear a little before we could stage. LOl, I also tried short burnouts, Nothing seemed to work. I did notice my front end not poping up like it use to and transferring the weight, So I changed front springs and that seemed to help, But Then my car lost power so it was hard to tell. Plus I burned all the tread off trying to hook.
Last week they were spinning through the first 100ft with me.
They felt sticky, But ever time I came off the launch control it went into a dead spin. Still went 1.7 60ft spinning, But I dunno,
I launched at 5500 @ 8-10lbs of boost off the line and 15lbs of boost WOT.
MeanGreenS13
hmmm ive got MH racemasters on the 5zigens right now ill see how they do whenever i get my injectors... 550s didnt work
rb25drag
Sweet man, So im guessing you got another good set of pistons in?
MeanGreenS13
ross..... not what i wanted but for 300 bux i couldnt pass it up but i need injectors BAD
rb25drag
Here is a video 2 weeks ago: This was with the megan coilovers and 12PSI in the BFG drags, with a 5500RPM launch @ 10PSI off the line, Spun ALOT!!
Here is another video from 2 weeks ago. I put the Stock rear springs and Struts in, Megan coilovers on the front with a 5500 launch, 8PSI in the rear tires. Did the best 60' on this pass at 1.7 that night and the best pass that night of 8.06 @ 87MPH. Still spun hard off the line . I talked to the mustang guy afterwards, Said he's running a 302 with 125 shot, 373 gears with a t5 transmission. I got him by 3 cars at the 1/8th.
kentuckyslider
Tell me how to post a video on photobucket and I will post a 7 second pass next weekend if it's not to hot. I am doing a KA to SR transmission swap this weekend and running new wrinkle walls next friday night. Should be in the 7.5 range if I get a good 60'??? by the way how is your 2 step working out for you? It looked like it came out hard against the mustang with 125 shot!!!
rb25drag
Are you registered on photobucket?
If so all you need to do is look were you download the pics and there is a video section. Just click it and you can upload it off your PC.
The Gizzmo works great. I wasn't holding it long b/c I keep spinning, But it did do better against the mustang. That was the last run of the night.
I went last weekend, But I blew my coils, The car quit making any power. So I gotta figure out what happend.
I would love to see your 7 sec video!! I was hoping for alot better myself.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
good stuff
kentuckyslider
It might be to hot tonight to get a good pass. I won't run until midnight but the humidity is going to be rediculous.
MeanGreenS13
so scott i picked up another set of welds LMFAO and an emanage, and 750cc injectors, and z32 maf... oh yeahhhhhhhhhhhhhhhhhhhhhhhhhh
rb25drag
LOL, IC you missed your wheels ALOT!!, So when will it run again?
rb25drag
Ya its been around 95-100 here every day with a ridiculous humidity. So how did you run?
kentuckyslider
1st pass my oil return from my valve cover melted and blew oil all over the manifold. I smoked the track out like James Bond and still ran a 8.1@71mph lettinng out at after half track(I usuall MPH in the low 90's)!!! The wrinkle walls and the 4.36R&P come out like crazy but they scare the hell out of me. It took me about 30-45min. to let it cool down and get it fixed and then my best pass was a 7.90 but I kept boggin off the line scared I might break the transmission or driveshaft again. If I would have ran all out the 1st pass I would say something like 7.5@93. Once I get used to the tires it is capable of sub 7.5 in the 1/8th for sure in cooler conditions. I will try to load my smoked out pass on photobucket. I need a 2 step bad!!!!!
rb25drag
Thats Really good in the heat man!! You got some power on me.
What Kind of 60's were you cutting?
Im not 100% sure that my 2 step isn't messing with my coils.
Im having firing problems again. My first Gizzmo 2 step unit I got was Bad, It kept cutting cylinders. Which is Kinda the same problem Im having right now. Im going to buy a new set of coils and HOPE it take out my problem. If not I guess Ill have to run without my 2 step.
But Im going to change my turbo over the Winter and Switch to Propane for fuel. Im going for Big Boost and Alot of power now. Hoping I can find a Way to hook about 600 to the wheels Next season.
MeanGreenS13
i would say 1 month away from RUNNING.. 2 away from TUNING, 3 away from SELLING hahahahaha
rb25drag
MeanGreenS13 wrote:i would say 1 month away from RUNNING.. 2 away from TUNING, 3 away from SELLING hahahahaha
LOL, Your just like me. I have said im selling for years, But I keep throwing more and more money into it.
MeanGreenS13
i need to move to MA in jan or feb for a job, so i dunno if i can keep it lol
rb25drag
Ya thats Understandable. Gotta have a good job to do anything.
If your like me, I wish I had built a turbo v8 instead!! It would have costed about the same and there is more buyers on the market for that stuff. its hard to sell our cars for much of anything.
MeanGreenS13
ill prolly end up going back to stock car racing shortly after i sell it. I miss it
rb25drag
Nice, I love some dirt car racing myself. I have 2 cousins that race it. One a Super Late model and the other a FWD. I have been in both, Its awesome No Doubt.
What class you run?
Return to “Nissan Drag Racing Forum”
