For the win. Thanks! I appreciate that!elitefew22197 wrote:Also, we have an entire forum dedicated to KA-T setups. They have helpful information like
ka-t-components-required-for-this-amoun ... 83590.html
Haha, my clutch is heavy as fyuck, makes me feel the same way! If you plan on running more boost id look into some kind of boost control. Also was the shop able to give you any insight on what kind of engine work/mods? And what kind of electrical things are you upgrading?sabretooth91 wrote:Yeah, I have 550cc injectors. I was recommended to get 83 lb injectors, which I believe equals out to 871.5cc. That looks a lot bigger to me!
The injectors are forcing me to max out at 11.5-12 lbs of boost. I was hoping to get around 20 lbs. I have a couple other electrical things I want to upgrade as well. But, I'll just get used to it like this for now, and upgrade over the winter, while its garaged. This clutch is something else. Very "grabby", and right at the top of letting the clutch our. I feel like a rookie stick-driver all over again!
Still couldn't be happier though.
That is strange, if you hadn't upgraded the clutch from stock I would say your clutch was slipping b/c of the additional power. Maybe your slave cylinder is going out or something? Could someone with a little more knowledge on transmissions chime in here?sabretooth91 wrote:I have a manual boost controller and a boost retard. I'll be upgrading the ECU and the Engine Management.
Strangest thing happened the other day. The car has been running fine since I got it. Then, after I had been driving for ~an hour, whenever I pushed it hard the car would slip out of gear when it really started putting down the power (4,000 rpms). The rps would skyrocket really quickly, but it wouldn't be making it to the wheels. I had my foot completely off the clutch. This would happen shifting into gear at high RPMs and it would slip out, and if I start at low RPMs and ramp it up.
Yesterday, I took it out again to try it, and no issue. But I hadn't been driving it for an hour. (so at least it doesn't seem like I damaged anything.)
The clutch only grabs when I let it all the way out. so maybe when it gets warm, its just not grabbing tight enough. I believe it is a cable clutch, so is this just something that can be tweaked so it is engaged before letting the pedal all the way up?
Will do. Thanks!compactfean wrote:You're trans is hydro but you can adjust the rod on the clutch master where it connects to the pedal to engage sooner. If your slave cylinder gets stuck in any given spot it can make the throw out bearing nit disengage all the way. Id get someone to press on the clutch pedal and watch the slave cylinder and sere if it appears to be working properly.
