KA-T "Components required for this amount of power" breakdown.
PapaSmurf2k3
Site Admin
There have been a lot of "what do I need to get me to XXX horsepower" questions lately, both on the board and by email, so I figured I'd slap together this quicky list here. Feel free to post any edit suggestions or questions. If you are reading this, and there is something you see, but don't know what it is, please try doing a NICO search before asking.
Basic KA-T setup (180-220whp)Required:T25-T28 sized turboTurbo Manifold (JGS?)rrfpr (8:1?)oil line kitsome sort of wastegate (if turbo isn't internally gated)
Suggested:Everything in required, plus-FMICupgraded clutchWalbro 255lph fuel pump370cc injectors + SAFCBlow off valveexhaustHeat shielding for the turbo or brake master cylinder resevoir
Medium KA-T setup (230-300whp)Required:T28 or T3 turboTurbo manifoldclutchoil line kitWalbro fuel pump440cc injectorsSome sort of engine managementZ32TT N62 MAFFMICWastegateExhaustColder spark plugsHeat shielding for the turbo or brake master cylinder resevoir
Suggested:Blow off valveboost controllerboost gaugeadjustable fuel pressure regulator
Advanced KA-T setup (300-400whp)RequiredT3/T4 50 trim or similarTurbo manifoldWastegateFMIC550cc injectorswalbro fuel pumpEngine managementforged pistonsZ32TT N62 MAFClutchoil line kitexhaustColder spark plugsHeat shielding for the turbo or brake master cylinder resevoir
suggestedBlow off valveboost controllerboost gaugeadjustable fuel pressure regulatorforged connecting rodsIgnition timing control with engine managementwater/methanol injectionARP hardwareLimited slip rear diffRacing radiatorManifold heat wrapT-bolt clamps on all charge pipe connectionsLarger fuel rail
Monster KA-T setup (400+ whp)requiredGT35 Turbo or similarTurbo manifoldWastegateFMIC850cc injectorswalbro fuel pumpEngine management (fuel and ignition)forged pistonsforged connecting rodsZ32TT N62 MAFClutchoil line kitBlow off valveboost controllerExhaustWater/methanol injectionARP hardwareHead GasketRacing radiatorColder spark plugsHeat shielding for the turbo or brake master cylinder resevoirLarger fuel railT-bolt clamps on all charge pipe connectors
suggestedLimited slip rear diffFlywheelWheelsBrakesTiresroll cage (required at some tracks for faster cars)Manifold heat wrapFire extinguisher (required at some tracks)
I know I'm forgetting some stuff... but its a start.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
PapaSmurf2k3 wrote:... 8500cc injectors ... I know I'm forgetting some stuff... but its a start.
!!!!! What are you building???
biggie
Fixeded the '8500' thing.
scotty-2-forty
biggie wrote:Fixeded the '8500' thing.
Man, I was lookin' forward to that build! Good stuff though. : May I suggest adding:
- 'Colder' spark plugs- A higher rated PSI radiator cap- Heat shielding for the turbo so you don't roast the brake fluid resevior- Gauges like Oil Temp and Press, boost, AFR ... - Adjustable fuel pressure regulator, 'quality' fuel filter (no paper), upgraded fuel lines, larger fuel rail.- Larger cams- Heat porting- Maybe a driveshaft loop for safety- Some sort of fire extinguishing capability whether on-board or hand held- T-bolt clamps on all piping connections and a bead welded to the edge of the charge pipes so the clamps have something help grip on
Yes, some of the above may be 'power' specific, but then I'm in the 400+ club.
Modified by scotty-2-forty at 1:37 PM 3/17/2010
Gabes13
Car: rb20det s13
This is like the same thing on ka-t.org.
HGOTBOOST
Car: Camry
bump for some good info.
frapjap
'07 Subaru Legacy
How about some estimated TQ numbers?I'm sure some of the guys here with the estimated builds could toss in a range?
WDRacing
In 02 I was looking at the Summit Racing Compact drag car...it had 3 110lb injectors per runner. I believe it was a 3.3 liter motor...same day they broke whatever the current speed/time record was in the country.
That was a good weekend. Granted they were using methanol...but still. That's a fire hose worth of fuel
WDRacing
pandapants wrote:This is like the same thing on ka-t.org.
A basic component breakdown is something we didn't really have. Just because the .ORG has one doesn't really matter. I'm quite sure that every forum worth a damn has a basic parts break down for various (blah blah insert forum topic here).
Nothing against the .ORG....just saying I'll come up some additions tomorrow and possibly edit the main post to reflect what we can all come up with
WD
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Sweet info.
DMan II-40
Car: 1995 240SX SE
good basic info to start someone in the right direction.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
bump for a good thread. why no sticky? :gotme
Gundyy
Car: 2000 Dodge Dakota 4.7L 4x4
definitely would have saved a lot of time for when i got here :bigthumb:
1 question: engine management system is like a piggy back system or stand alone? or both?
PapaSmurf2k3
Site Admin
Engine Management is sort of an all encompassing term meaning "something that can alter your fuel and/or timing (among other things)". To what degree it can do that (and how much you need it to do) is based both on how much power you want, and how much you are willing to spend.
Piggy backs for low budget, low HP goals, NISTUNE & full stand alone for the big boys.
mixeds14
Car: 240
dont foget ur tuned ecu's.... like jwt,ethalpy, ect..
PapaSmurf2k3
Site Admin
mixeds14 wrote:dont foget ur tuned ecu's.... like jwt,ethalpy, ect..
Yes, especially when coupled with a piggyback (to fine tune), you can get a great setup from them.
Dub's
What if i need 800rwhp+?
WDRacing
V8 Swap is your best bet if you truly need that much power.
PapaSmurf2k3
Site Admin
The boys over at AMS (http://www.amsperformance.com/) built a 1000 hp KA. It was quite expensive, and took a lot of effort and in-depth technical know-how.
GodzillaS15sx
Car: In planning stages currently to build a 240sx (still investigating options for the motor), '14 Hyundai Elantra GT
This was a great write up. I am currently in the planning stages of a 240 build and my end goal is 400-450whp :dblthumb: and I would like to be able to drive the car without it being too "drag car like"
Is this a realistic goal for a KA-T build? And Yes I understand that it will take time and planning, and money to put this together but if my goals are a tad lofty :ohno: for a KA-T then I need to look towards another engine :facepalm: . Thank you in advance.
WDRacing
GodzillaS15sx wrote:This was a great write up. I am currently in the planning stages of a 240 build and my end goal is 400-450whp :dblthumb: and I would like to be able to drive the car without it being too "drag car like"
400-450 is doable. It's not even that complicated really. You need fuel injectors big enough to support that much power plus the MAF and ECU to go with. A fully built motor and cooling system. A turbo large enough to support that without becoming a heat pump. A set of cams wouldn't hurt either, allowing you to make more power with less boost.
Just money and time really.
WD
GodzillaS15sx
WD
Do you mind explaining this? And what size turbo would be sufficient to get to that range? Ive been reading that Holset HX35 are decent even though they are from diesel trucks, or would it be better to go with a Garrett, Greddy, Precision, BW etc.
Also are there ECU set ups that would allow two programs where you can change by pushing a button or hooking up to a laptop? what I mean is when you get a JW (or another professional tune) do they have things where you can have a street tune say 12 psi and a "track" tune where you have 24 psi? or do you have to have just one program in the computer? Im a dreamer what can I say...if I have to have one tune program the wife wont be driving a 450whp rear wheel drive anything... :woot:
WDRacing
A small turbo will have to spin faster to create the same amount of boost as a larger turbo. The faster the compressor spins the hotter it's aircharge becomes. It also becomes inefficient past a certain point. A GT35, Holset HX35 or any turbo of similar size from one of the reputable companies you mentioned will work fine. You'll be running between 20 and 25 psi to make 450WHP depending on supporting mods and such. There are some really awesome turbo's available these days. The turbo selection has a lot to do with budget. I'd recommend ball bearings instead of journal bearings. Obviously stay away from knock-off brand turbo's. They're all junk.
As far as the tune goes. Lets say you go with a Jim Wolf or Enthalpy ECU. They come tuned to work with a specific injector and specific MAF as a matched set. So it's important you buy them as a set. If you get an ECU tune that supports 100lb fuel injectors and a 300ZX MAF you'll be able to run 25 psi of boost. That doesn't mean that you HAVE to run 25 psi of boost.
The boost level is determined by a boost controller. I personally use an old fashioned TurboXS Dual Stg controller. Inside the cockpit there is a toggle switch. One position for low boost, one position for high boost. There are electronic controllers that will do the same thing. The ECU controls fuel flow and ignition timing based on the signal it receives from the MAF sensor. So it can peter around at 12 psi all day every day or rip up to 30 psi on at the track. So there isn't a need for multiple tunes...unless you're running different types of fuel.
Don't be afraid to ask questions, even if you think they're noobish.
WD
PapaSmurf2k3
Site Admin
There are a multitude of turbos that would support that power. Cheap ones might not last as long, or spool as quickly, or take up more space, etc.
Check out www.turbodriven.com for Borgwarner turbos (and they also have a mapping tool)
and www.turbobygarrett.com for Garrett turbos.
Here's a thread about compressor maps, and plotting them on your own:
so-i-made-you-guys-some-compressor-map- ... 29705.html
As far as ECU setups go- if you go with a stand-alone system that utilizes a MAP sensor (otherwise known as speed density ECU), you can just have your tune go all the way up to your max boost pressure. At that point, your boost controller is all you need to determine your power level.
