KATwo40 wrote:Our PCV system is a positive pressure system and requires running the valve cover line to the turbo inlet pipe. The venturi effect creates scavenging. Otherwise, you get excessive crankcase pressure, resulting in some oil smoke and other crap.
Re-route that, then re-test.
On another note, turbo boost pressure has nothing to do with whether or not you need a restrictor.
Cars that don't run restrictors (Volvo, Saab, DSM, etc.) don't have 60psi running through the turbo oil feed line. It's a low pressure outlet from the block where the oil lines connect. There's a big difference.
According to Corky Bell's "Maximum Boost," it's recommend to have no more than around 35psi at the turbine housing oil inlet. Running the restrictor in the line is not going to starve your turbo of oil. I run a 1/16" restrictor and -4an line. No turbo failure on the T3/T04E.
One other point to consider...
When the bearings wear enough to effect the seal, the turbo is pretty much shot. The bearing and wheel tolerances are so close that it doesn't take much shaft play from bearing wear to touch the sides of the housings (the wheels, that is).
If you're seeing the smoke @ idle and you know it's turbo seal leakage, it's the turbine side, which is not even a seal. It's a piston and ring design. Usually this wears as a result of oil coking.
First, a comment about the PCV...i've had it run both ways and there's been no detectable difference, not to mention, the smoking problem happened well after I had just put a breather on the valve cover line; it wasn't a concurrent problem.
I knew it was the turbo at fault because of the good compression on all cylinders and because it didn't smoke while decelerating under vacuum...There was also no excessive blow-by because there was no oil on the inside of the line from the valve cover.
I realize turbo boost pressure has no bearing on whether or not you need a restrictor; I merely added that point to convey that the turbocharger was otherwise functioning perfectly, and there was no detectable loss in power anywhere.
The smoking was coming from a clogged oil drain line, clogged from a LARGE chunk of coked 5w30 regular oil. When I took the drain line off after the turbo was out of a car a chunk fell out, and then I found a semi-circle chunk of coked oil with the diameter of about a quarter (money), and the thickness of about 5/16". If I had my digital camera, which is in some lucky hands down in the Dominican Republic, I'd take a picture.
The problem now is to figure out WHY the hell the oil coked so badly that it clogged the oil-return line. My street is about 1/4 of a mile, and I am never in boost coming up it after a ride, in fact, for the last mile drive to my house, I'm never in boost. I ALWAYS let the car idle in the driveway while I wait for the garage to open, and then I ALWAYS let the car idle at least 30 seconds in addition to letting it idle on the driveway while it's actually in the garage. In other words, I am very conscientious about making sure the turbo has time to cool down. I am also running a very efficient front-mount oil cooler, which no other KA-T i know of is running (except for AZHitman, who is running my old setup).
Now if I had been using a high-quality synthetic oil, chances are it wouldn't have coked like the regular 5w30 and blocked the drain-line. Only reason I wasn't running synthetic is because, as I've said before, the engine only has 2000 miles on it...it's just been broken in and I wanted to wait for everything to break in before switching to synthetic. Guess I waited a little too long.
Nonetheless, even regular oil should NOT have coked like that so easily and so quickly (this was a LARGE chunk), considering I always let the engine and turbo cool down by idling it. Only other thing I can think of is that the tiny orifice of the restrictor, coupled with the fact that oil-pressure is lowest at idle, didn't let enough oil flow through the turbo while the engine was idling to properly cool the turbo down, causing the oil in the center section to coke. I understand the theory behind using an oil restrictor, but the oil didn't coke in the turbo just from me being an idiot and boosting it real hard and shutting it off suddenly, nor did it come from overly hot oil in the feed-line. The ideal thing (although prohibitively complex) would be to use some kind of needle-valve actuated from the cabin that can bypass the restrictor when the engine is idling and just about to be shut off to assure there's plenty of oil flow; during driving, however, the restrictor would be used. Too bad this couldn't be done very easily.
I should add that I, as well as many other people, have run successfully and for quite some time without an oil-restrictor on the feed-line; my old turbo was on there for about 4000 miles w/o a restrictor and never ONCE did it smoke, and the seals/bearings on it were fine when I removed it.
The car has only been driven about 10 miles since I noticed the smoking problem, so instead of wasting $ and time re-doing the bearings and seals, I'm going to re-install the turbo after I thoroughly flush out the center section area and see if it smokes anymore; now that theres no chunks blocking the drain line, the oil won't need to be forced through the seals. Hopefully the damage isn't 100% irreparable. We'll see though...The shaft-play on the turbo isn't that bad...both wheels spin freely and there's enough clearance between the wheels and the housings.
Right now I'm going to put the turbo back on, switch to synthetic oil, and NOT run an oil-restrictor, and make damn sure I give the engine even MORE time to cool down. If the smoking gets even worse then I'll know it's due to the excessive pressure from not using the restrictor and I'll bite the bullet and re-do the seals and the turbos. However, it's tricky, because now that the seals are ALREADY probably damaged, it could smoke more due to the higher volume and pressure of unrestricted oil flowing through the damaged seals, oil that perhaps would not blow-by the seals if they were undamaged. Again, I ran for quite some time with no problem with an unrestricted feed-line.
Maybe I'll compromise and use a restrictor that's substantially larger than the old one but still smaller than the regular feed line, but there's no way in hell I'm using that tiny .060" one that I bought from ATP a while back. If anyone wants it, it's for sale!
