tuning a CA18DET
GZL-19T
hey i was wondering what is the best air fuel raito to have my CA running at.. it has been fully rebuilt with forged pistons and 1.5mm headgasket and BB turbo.. and the timing.. should they be the same all through the rev range or is it better to change it around ?
float_6969
When you're underboost you want to be at 12:1. I'm not sure about the timing.
Def
Car: Cars, Engineering Stuffs
You definitely want to RETARD timing under boost. 0.75 degrees/psi of boost is a pretty good rule of thumb. So if your base timing is 25 degrees at zero vacuum/boost - then you'd be at 17.5* of timing at 10psi of boost.
These numbers are just theoretical, I don't really know what works well on CA's. I think the factory SR20DET computer runs about 14-16* of timing at full load in the upper RPMs if that helps.
float_6969
Def, I love the Avatar man. I was LMAO when I figure out what it was!
GZL-19T
12.1 is that a bit rich
biosehnsucht
Run rich to save the *****, lean out to take her out!
Nismo1182
Car: Z06
12.1 is fine.
Def
float_6969 wrote:Def, I love the Avatar man. I was LMAO when I figure out what it was!
Glad you got a kick out of it. :D
paul_s13
Between 12.5-12 : 1 is best depending on what fuel you are using, as for timing, as much as you can get away with before it starts to detonate really! :cool:
Jezz_s13
Car: Sil80 Track Car
Fook me it's Paul!!!
boost_boy
You don't want your total timing to get past 28* because after that is cranked ringland country.
Dee
paul_s13
Jezz_s13 wrote:Fook me it's Paul!!!
Ello mate, hows the car going?
Jezz_s13
Ok actually for a change LOL, just planning a mental attack on it, Pauter rods, huge turbo and 950cc injectors blah blah...looking for ~470-500rwbhp.
GZL-19T
fuel is like 98%.. so what would be to set it at if i wanted to have it the same all the way through...
when i change gears now it takes very long to come on boost like 5 sec.. some times more but if i hold it in the gear and then give it its ok.. hmm
boost_boy
Quote »when i change gears now it takes very long to come on boost like 5 sec.. some times more but if i hold it in the gear and then give it its ok.. hmm[/quote] What are your turbo specs? I always warn people about really huge turbos on the CA especially when it's just a street car, but no one listens (Good for them). But if you have the stock T25, I would suspect the turbo is failing if everything is in good working order.
Dee
paul_s13
Jezz_s13 wrote:Ok actually for a change LOL, just planning a mental attack on it, Pauter rods, huge turbo and 950cc injectors blah blah...looking for ~470-500rwbhp.
Kewl, what did you do for a manifold in the end?
GZL-19T
i got a BB T28 and has been hi flow'd ...around 380hp
it did not use to do it.. its all brand new ran it in 1000 ks all good.. took it for a run up the coast 2 hrs each way.. was sitting on like 4k+for some time and its done it sence...
could it be that its a after market computer and it needs to be tuned again sence its been run in more ?
Jezz_s13
making a top mount one.
paul_s13
Jezz_s13 wrote:making a top mount one.
Your making one? Last time i remeber a post of yours you didn't have much confidence in your welding abilities, practice makes perfect though innit!
Top man if it works.
boost_boy
Quote »i got a BB T28 and has been hi flow'd ...around 380hp[/quote] When does your boost come in? What size back housing do you have? If it's one of the S15 thinga-majiggies, then this would explain some of the hesitation or lag. I think your situation is ideal for others to learn from. Your turbo is not what the factory prescribed for this motor. The T25 and it's .48 housing is what the factory issued for the CA18DET. S15 carries a .64 housing (IIRC) and you will encounter some lag from it. Whereas the SR20 and bigger engines flow enough CFM to get these turbo moving at lower rpms.
Oh yeah Jezz_S13 and Paul_S13 you guys are officially thread jacking:ylsuper
Dee
GZL-19T
boost comes on at 4g.. if i dont give it just cruze from 1st to 2nd and then give it when its in 2nd its fine.. its just when im giving it all and change qhick and put back on it will boost to like 3psi and take so long to get to like 7psi.....like to 6g rpm..
do u get what i mean?
boost_boy
Quote »do u get what i mean?[/quote] I sure do! that's what happens when you step up to a bigger turbo. Answer this question, what did you do with the butterfly assembly on the intake manifold? Did you leave the butterflys open by not attaching a vacuum hose or do you have vacuum on the actuator pump?
Dee
GZL-19T
they are always open.. i dont have any vac lines they got removed with microtech was put in..
i put picks up if u can remember..
i have always had a T28 on my CA i just put a BB one on when i did the rebuild.. it did not use to do it tho
Jezz_s13
true true but we are technically talking about CA tuning. :)I'll shut it/zip it, now. :)
boost_boy
Quote »true true but we are technically talking about CA tuning.[/quote] Tell me anything! I have a soft-spot for my fellow CA brethren:D
Dee
GZL-19T
hmm not too sure.. i might get it dyno tuned tomorrow
might be able to fix the problem then...
got my rx7 450cc in the mail the other day.. thanks gerry :).. looks like they fix right in.. plug is the same and all.. they are the brown top ones :)
boost_boy
You're using the microtec, right?
Dee
GZL-19T
yep with the bosch coils
boost_boy
The few people I know that are using the microtech on the CA18 are aborting them. I would defintiely be checking the timing.
Dee
GZL-19T
ah ok.. i have not herd anything bad about the microtech.. what have u been told / come accross ?
