Trying to unleash the beast. Tuning my M56S
1GR8M56S
Car: 2013 M56S
Thanks guys
Ilya
Yeah UpRev is notoriously bad at customer service. I'd go to a tuner.
AlphaSnacks
Car: 2013 M56S Aero
1GR8M56S wrote:I bought uprev I just need to know what changes to make and where to go on the program,you guys mentioned you had to purchase an additional rom for $200, stuff like that. Thanks for responding.
You will need to do a rom dump first, which means you'll have to make a copy of your ECU file and send it to UpRev so they can unlock it. We have Gen IV ECUs in our cars, which are different than the easy ECUs of Zs, Gs, etc.
Or you can go to a GOOD tuner who can do the same thing for you on the spot and then tune it. But I highly suggest you do an exhaust modification (I suggest custom exhaust), otherwise the tune doesn't gain as much. Getting rid of the Y-pipe for 2 straight pipes makes an ENORMOUS difference, but you will have to cut it off. The noise of the car hardly changes - it just allows a lot more exhaust flow.
1GR8M56S
Car: 2013 M56S
Thanks, I did a stillen cat back and I was debating whether to get rid of the y pipes and put the straight pipes because of noise, but if you say it doesn't I might just do it, on the stillen site they sell an additional piece of exhaust with or without the cat has anyone installed this piece? Or have any suggestions?
adeedpb
Car: 2012 M56
2005 BMW X5 4.4i
2005 G35 Sedan - SOLD
1995 Ford Taurus SHO (Supercharged) - SOLD
Y-Pipes are the first thing that goes when my warranty runs out and then UpRev.
UpRev changed my G35 in to a completely different machine; but a good tuner is absolutely key!
twostep361
Car: qx80
off subject but do you have 20x10.5 squared? if so whats your offset and size are your tires?
AceGang
I'm curious about the offsets and tire sizes as well.
walt1227
Car: 2011 Infiniti M56S
Just found this video on youtube. All the guy did was a custom cat-back exhaust, K&N filter replacement, and a tune. Got 27HP increase and 34lb ft tq putting the power to 457HP/506TQ.
https://www.youtube.com/watch?v=xTHtBju9TRM
Pimperish1
Car: 2011 Infiniti M56s
2007 Nissan Pathfinder S 4WD
2018 Nissan Rogue SV
2020 Nissan Rogue SL
Lots of good info guys. My Stillen near cat back arrives today. Had I seen this post sooner may have considered deleting the Y pipe and doing a custom. No worries though, that new exhaust splits to dual pipes after the Y pipe flange so I can still delete the Y and have a shop run two pipes back into it so I keep the remainder of that sexy stainless steel. Gonna bolt it on as is this w/e, I can't wait much longer. What's the feeling on that second set of cats, delete as well or keep? There's no O2 sensor after them so I'm guessing the ECU won't mind much. The stock pipes were sh*t, both mufflers were cracked at the flange weld and one had completely broken off.
TheMajesticKing
Car: '11 M56S Aero
Wheel Specs:
Square Setup
Size: 20 x 10.5"
Offset: +27
Tires: 275/35/20
