Trying to get my sr20 in my car already (the process)
[TRE05]97ka24DE
Car: 1997 Nissan 240sx KA24DE
To start off this is The car Im droping the sr20 into..
I bought an s13 sr20 a couple months ago (got a good deal) and up until a few weeks ago I have started to piece it back together. this is my first Sr so I know I will run into some bumps and this site has been very helpfull to me so far. For months Ive been on this site and others in the for sale section looking for parts. so far Ive bought-
new head gasketT25 turbo and all elbows (engine only came with the exhaust mani)starter exedy stage 2 clutchengine harnessMass air flow sensorsr20 intake pipecoils packs and harnessigniter3in downpipe
Heres the first pic I took of the engine but basically all I did before this point was clean up the engine( wasent really that dirty) and removed the head for the new head gasket
now i know its outside but Ive rebuilt some of engines before and really the only time I ever had the internals exposed was when i took the head off. and it was off for like 20 mins when scraped and cleaned the old gasket off.
before the new headgasket came in the mail I decided to touch up the valve coverFRESH
Modified by [TRE05]97ka24DE at 11:45 AM 10/6/2008
[TRE05]97ka24DE
This is how it looks with the head and valve cover back on
Neil
Car: shooting laser guns
Good luck with emissions, champ.
http://www.deq.virginia.gov/mo...dfail
If I were you I'd try to spin a profit on the motor, and go KA-T w/ Piggyback management so you won't be eliminating OBD-II.
[TRE05]97ka24DE
Where I live we dont have emissons testing. The only thing they look for is if you have a cat bolted up. They cant even check if its hollowed out or not. they dont smog test its not the law over here. Just a visual inspection. yea Ima miss OBD II but tons of Sr20 people do without it. Ive maybe used my OBD II port once in the year that Ive had the car. And I have never had a tech check if the port works while doing an inspection. So its not a problem.
nzmoman
Car: 240sx 2 of em' and always lookin for more
yeah as long as you are sure. I am running a OBD1 in my Kouki. fortunately I don't have to worry about emissions because I have a home outside of the metro area.
[TRE05]97ka24DE
^ yea were in the same boat Im good with emissons
any way cleaned up the intake 2 day and bolted it up and connected all water lines.
these were pics when they were dirtyIts cleaned up now bolted up sorry about the cell pics TB now attached
[TRE05]97ka24DE
any ideas as to where these hoses go ???
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The bottom gets capped off. The top left goes to the fuel regulator and the top right goes to the bov depending on your setup. More responses to come! I shipped your lines out also!
Neil
It doesn't have to be capped off.. I use them all. One for the FPR obviously, one for my BOV and the third one has a line routed through the firewall for my analog boost gauge + ebc's control box.
P.S. I'm amazed and green with jealous rage that in certain states there are counties that do not require emissions testing.
MastaYu
Car: 92 Nissan 240SX SE HB
nice looking good so far
[TRE05]97ka24DE
Modified by [TRE05]97ka24DE at 9:46 AM 10/7/2008
[TRE05]97ka24DE
Thanks for the input guys. And thanks for shipping out the t25 lines! That's the last thing I need to put the turbo on. Connected all the turbo elbows and stuff today. My turbo elbow was missing 2 studs and only came with one stud for the downpipe and it was stripped! But I found a cheap solution and now have new threads. Pics to come later on today.
[TRE05]97ka24DE
what do you do when you missing studs? Go to lowes and buy sum new ones. 90 cent a piece and the just thread right in.
test fit PERFECT
Modified by [TRE05]97ka24DE at 7:48 PM 2/4/2009
[TRE05]97ka24DE
Ran into a problem. It speaks for itself... this 02 housing is made for the fat on not the skinny one.
O and this seals the deal on knowing I have a red top. someone painted over the red valve cover black O well same output. wish I would have known before I repainted it black it still looks bad *** so Im good.
godzilla34
Car: nissan 240sx sr
that valve on the back of the intake mani. is for you brake booster line. theres a hard rubber hose that connects into it. looks good hope the swap runs well!!
Sil80315
Car: 1991 Nissan 240sx
I have a fat o2 sensor if you need one. and the wires are already extended
[TRE05]97ka24DE
Hey guys I know its been a while but I havent stopped working on the engine. I got the turbo and lines all connected up (minus the oil banjo bolt) anybody know the part number for it? Its smaller than the others for some reason?? Anyways here we go and better pics now 2!
all new gaskets
[TRE05]97ka24DE
When I was taking pictures I took the flywheel off to get resurfaced. I can not belive how rusted this thing is. But this is how I bought it. It took a while to come off but at least its off. While Its off Im going to go ahead and replace the real main seal. But its going to the machine shop tomarro.
va240dude
Car: 1992 S13
nice work man, that is a great shell for a swap! I'm working on my 1st SR20 over the mountain from you in Harrisonburg. I'd love to see it when it's finished. keep up the great work.
Nismo24zero
Car: 05' Nissan 350z
great project looks great
Neil wrote:It doesn't have to be capped off.. I use them all. One for the FPR obviously, one for my BOV and the third one has a line routed through the firewall for my analog boost gauge + ebc's control box.
so you can use the bottom one for your boost gauge, sweet i've been trying to figure out a good spot to tap mine in to. thanks.
and here's ohios emissions testing, when you go to register the car they ask you to rate it good, fair, or wrecked condition. they dont even look at the car. then they issue you some plates and say have a nice day. you could have no exhaust on it at all, they dont care
[TRE05]97ka24DE
^Thanks!got the fly wheel resurfaced what a big difference.
I was missing my TO bearing and The thing that holds the TO bearing (TO bearing carrier) anyways I picked them up 2day from the dealer so The transmission should be going on 2mar. I will post pics.
Modified by [TRE05]97ka24DE at 10:34 AM 11/14/2008
positron1
Man that's clean!
duffman1278
Car: 89 240sx Hatch, the wildcats!
haha thats how mine came out but dam mine wasn't rusted THAT much.
Good work. I suggest cleaning out the IACV also incase you havn't. Take out the spring and clean it and what have you.
GL
redsx13
Car: 93 240sx 03 350z
that thing was rusted out pretty good.... o well thats japan for ya. when i got my clip, the whole thing was rusted out.
ya.. dont feel to bad on the being a red top thing....I found out that mine is a red top and was an automatic. an exhaust bolt was snapped off, drilled out, retapped, and then stripped again, my turbo oil line is stripped out at the block and leaking oil badly. i had to replace the maf, the ecu, and the injectors. and it still doesnt run correctly.
someone shoot me !!!
[TRE05]97ka24DE
Got some small stuff done yesterday. I put in a new rear main seal and pilot bushing. the only thing thats keeping me from putting the transmission on is that I dont know if I should get lockwashers for the pressure plate bolts. Or should I just put lock tight on them???????? motor set didnt come with any so i have no clue.
new rear main seal installedthe new pilot bushingPilot bushing installed
snake240
Car: 92 hatch SR20DET
lookin good man.
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I really hope you're not using nylon-insert lock-nuts on your turbo elbow (O2 housing)...
With the temperatures that the turbine sees, you're going to melt the nylon in no time and those bolts might back out.
Use heavy duty split-lock lock washers instead.
[TRE05]97ka24DE
^yea I was going to swap them out.Havent updated in a while lost my camera but I got a new one. a friend and I put on the resurfaced flywheel, clutch, and bolted the transmission up. Then I found a lightweight flywheel . I know but I figured it would be easier to put on now then when in the car. anyways took the transmission off and replaced the flywheel with this Act lightweight one.
New Throwout bearing and new carrier
Forgot to take a picture of the clutch but its a exedy stage 1. so as of right now the transmission is bolted on [EDIT] I found some from the first time when we put it on. Its with the old flywheel but these are just pics to show you what the clutch looks like.
Modified by [TRE05]97ka24DE at 8:24 PM 2/4/2009
Modified by [TRE05]97ka24DE at 8:26 PM 2/4/2009
Kalypso
keep it up, great job.
[TRE05]97ka24DE
Got some more pics for you guys and I kinda got bad and good news. I was driving my GF back home and the Ka24 started acting up. I mean BADLY. So f**k it the sr20 is pretty much complete so Im just going to swap it in. Need some small things to be done and she will be ready to go in. Clutch pedal, shifter, the clutch hardline bracket, Im going to the yard tomarro morning so hopefully I can get all that stuff I need off. heres some recent pics of the motor its almost complete and waiting to go in. I got a tubular mani from a local guy out here its heat wraped so hopefully it wont crack LOL
Heres a small colection of parts I got recently ( non abs 5 speed drive shaft, xmember, in the big box I got my V mount setup YES MY V-MOUNT SETUP!!! with a blitz blow off valve on the hot pipe, intercooler and radiator w/electric fansthe other two boxes are the manual brake pedal and s14 speed sensor
Like I said the motors going in so Im going to be taking lots of pics!
Modified by [TRE05]97ka24DE at 9:10 PM 2/11/2009
