Trying to get my sr20 in my car already (the process)
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Do it to it!
pauliedrft
Car: 91 240sx
god i wish mine was this far along ,nice work looking good .
[TRE05]97ka24DE
Car: 1997 Nissan 240sx KA24DE
I put my s14 manual brake pedal and my clutch master cylinder in today. It was A PAIN i repeat A PAIN getting the old brake pedal out and the new one in. I took pleny of pics enjoy.
Automatic brake pedal
First thing you have to do is remove this small box. Two bolts hold on the bracket that welded to it.
Once off remove the 10mm bolt so the clip can you an get the box out off your way
Next thing you have to do is turn this nut with an open end wrench so that you can free the MC from the accual brake pedal assembly
Remove both of these sensors because they will get in the way when u are tring to get the pedal out and belive me you need all the room you can get. Loosen up this bolt and then just thread the sensors out by hand
Remove the bolt thats holds up the top of the brake pedal bracket.
Remove the 2 nuts on this side of the bracket and the other 2 on the exact other side. The pedal assembly is now free.
Now with the assembly free Spend 10+ mins moving this thing and cussin at everyone in the world til its finally out
The install is the reverse of the removal, install and enjoy
[TRE05]97ka24DE
Seeing how I was down in this area i figured i would install my clutch cylinder
I tired to get at it with a hole saw but since I get the dill flush the hole saw wouldnt work. So i got a small drill bit and took some advise a friend told me about.
I drilled holes about every 1/8 of an inch all around the imprinted circle
Then I took a screw driver to it and hit it with a hammer in between each hole
When its almost out just grab it with some plyers and yank it out
Its looks choppy
So I took the dremel to it and smoothed it out
Drilled the two holes that hold the clutch clyinder up.
And installed the clutch cylinder
weeman0987
Car: '89 240sx hatch pignose
man this guy dont know wat hes doin lol i was just at his crib and saw da wip loljk jk guys this my boy for real so ima hit u up tomorrow bra piece
Kalypso
keep it up
Neil
Car: shooting laser guns
I wouldn't wrap the header, especially If you're worried about it cracking. The wrap reflects the heat the header is trying to dissipate back at the header to keep the exhaust gasses hot, which can help with scavenging but it's murder for the piping.
[TRE05]97ka24DE
It came like that I really dont feel like taking it off. when it cracks I will go back to the stock one
240nicksx
Car: '92 hatch SR20DET '70 McLaren M6GT
what brand of exhaust manifold you got?
i have a tubular one just like this, wrapped and all, and it seems to do just fine, and i got megan racing bc i heard the tomei's crack alot
swaps lookin good man
vcuban
Car: 200sx
Do you know if i can fit a sr20det s14 in my 97 200sx? with no modifications
[TRE05]97ka24DE
Well as it stands for the swap right now I have completed convering the wiring for the s13 sr20 to work in the s14 chasis. All I have to do is figure out the wirng for the lower harness (manual transmission) because my s14 harness is an automatic. I got some pics of me and my friend pulling the ka24 out. It wasent really hard just Cold as f##k outside when we did it.
positron1
Halfway there...do it to it! Do you have any info on the lower harness wiring?
Slammed95S14
Car: 2001 R50
Man. This reminds me of when I did my swap. It was the best time of my life. I wish I could do it all over again.
But good luck on the swap!
[TRE05]97ka24DE
positron_ wrote:Halfway there...do it to it! Do you have any info on the lower harness wiring?
well as far as getting the eninge running with the lower harness the only thing that to be swiched out is the starter signal connector. because the auto one will work but the locking tabs dont match so it wont lock in. if you have the sr20 lowering harness ( which I dont) you can just swap plugs and your done. but the plug is a standard female connector you can buy so Im just going to buy and insulated one and it should work.
Now as for the transmission two sensors have to be hooked up. neutral position switch, and the reverse switch. I dont remember the wire colors but Ill post them when I do it. once again if you have the sr20 lower harness you can just extend wires and solder in the plugs to the sensors. BUT i dont have one so I hve to wire it directly into the sensors and basically bypass the plugs.
other than those 3 things everything else plugs up
[TRE05]97ka24DE
Gots some pics of me and a buddy dropping the sr20 in.
