ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Fri Feb 18, 2005 6:16 pm
Along with the bump stops check your trunk latch, (the part that hold the trunk once you close it), it's bolted to the body on the inside. It is ajustable, just loosen the 2 phillip head screws and move it down slightly, then close the trunk and check to make sure it catches. This may take a few trial and errors but it is fairly simple. Do this after replacing the bump stops though.
