Just popped into my head after some researching aswell, this truck is actually LOWERRED using 4x4parts springs.
Could the driveshaft somehow be compressing to much and causing some sort of bind/trouble enough to cause this? I do believe my shaft to be in poor shape, but I did just grease its zerk with wheel bearing grease.
My truck being 2wd might be different than most here but that "troubleshoot" just popped in my head
Replaced fuel filter just now after work (3am so awesome), took it for a spin after a good warmup and it changed nothing.
I forgot to mention the car threw 2 codes the first day I had it on the road and this system was acting up to the point of not shifting. I believe it was P1744 (torque convertor) and also a rear 02 sensor code.
It threw the torque convertor code I blieve in the first few miles of the problem because i was reving the engine to high while driving to see if it would shift. I erased the code and have driven about 15miles since at a top speed of 40mph in second (to and from work twice) and that code has not returned. The code for the oxygen sensor did come back on within a few minutes, I forgot to write down the P # again for that but it was a rear 02 and Im assuming not a big problem or causing the truck not to shift
Also getting horrible gas mileage, appears to have used 1/4 tank in 40 miles, but I am cruising in 2nd gear
