trouble with Convertible top
cacaface
Car: 240sx 93' Conv with manual sr20
Ok so I read the sticky on how to trick your car into thinking it's in park so that the top works again (swapped to man. obv.)
Anyway, me and my dad wired the brown yellow with the blue or whatever and it worked ONCE. We put the top down and it worked fine, but then when i tried to put it back up, it didnt make and noise or move at all. Blown fuse or something? I redid the wires, but still wasn't working.
I haven't hooked up the reverse lights or anything yet, but that doesn't matter right? Anyway, looked around the car, but couldn't find any fuses or anything, any help would be great, THanks
Eikon
Car: 71 240z, 93 Supra TT
Be sure to check the pump in the trunk. I'm wondering if you are low on hydrolic fluid or something like that. Just give a visual inspection of the pump to check the vavle to make sure it's in automatic mode, and to see that there is enough fluid in the reservoir.
If that's not the case.. then check for blown fuses.
If you got the wiring right to make it work once.. it should work again and again.
Reverse lights wouldn't have any influence on it, so you can rule that out.
cacaface
As far as I could see, the resiviour looked fine, but I'll have to check again in the morning. Any idea where the fuses would be? Thanks for the help
vertbish
Car: 94 240sx convertible
This might be a little bit helpful, you just need to search around first.Everything you need to know should be here.zerothread/188187
Eikon
good help vertbish!
This thread might be a little more pertinent to 'verts. It's the sticky thread atop our forum. Ton's of good help here. zerothread/199318
make sure you download the 'vert FSM so that you have it handy.
cacaface
ya I can't find anything helpful for my problem. I wired everything up right, but it's just not working. only worked once
