 The ULTIMATE 240SX Bible Volume 1
sstomek
chicago il
8-3-2005
Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
240SX Tech Articles
^^^^don't forget that one, it was pointed out to me after i made this post...damn you AZHitman where were you when i needed you most^^^^
Electronics/ECU
ECU pinout diagrams.
REWIRING YOUR IGNITION COIL
Distributor Timing
Removing speed limiter on 93 KA24DET
DIY Ignition Mods for Better Spark
Sr20det Ecu Fault Codes
SR20DET ECU wiring diagram.
FAQ: KA ECU # Glossory
A long tutorial for tuning nissan's ECUs
How-To: Chip Your ECU with Pictures (KA24E)
Desoldering tips
Battery Relocation
Engine/Engine Info
SETTING THE BASE TIMING ON THE DOHC PROPERLY
How to build a KA24DE
How to: S13 Oil pan removal
DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE
How-to: Build Your Own Oil Cooler
S13 Red Top Vs. S13 Black Top - The differences
DOHC Turbo For Dummies
240sx Engine Descriptions
240SX How To: Removing/Replacing your PS pump
DIY: ITB's for your KA24DE
Basics of engine management
SR20DET Installation Guide
Engine Knock (Detonation) Sensor Replacement (KA24DE)
Transmission
How To: Convert from A/T to M/T
How to Swap Your Auto Transmission for a 5-speed
Changing transmission fluid / oil on s13
How to install paddle shift on an automatic 240SX
240sx Clutch and Flywheel Swap
Clutch Swap
Fuel
REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's
240sx: Installing a Walbro Fuel Pump
240sx: Replacing Your KA24DE Fuel Injectors
DIY: Installing an injector resistor box
Turbo
HOW TO NEVER OVERBOOST AGAIN
Bobby's DIY turbo oil feed/return lines install
Turbo rebuild DIY
Suspension/Differential/Brakes
Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential
The Definitive 300ZX Brake Swap!
Advanced Suspension Definitions
Rear differential swaps for the 240sx
Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion
Rexbo's Guide To Brake Caliper Rebuilding
ABS Removal
Interior
Removing the S13 Door Panel Fabric
Low-budget seat modification for S13
Re-covering Your S13 Glove Box
DIY: Window regulator repair 5$
DIY: Dye That Ugly Carpet!!!!! W/pics
Camera Mount
Exterior
HOW TO: Repaint Headlight Housing (Black)
DIY: Replacing Your Rusted Hatch
240sx Conversions - An Introduction
Sleepy Eyes walkthru (VID)
240sx Vented Hood DIY
Rust removal, Fiberglassing, and Body Filler
DIY: Silvia Foglight Wiring
Factory Service Manuals/Diagrams
Factory Service Manuals (FSMs)
Your home for factory service manuals
Parts Lists / Diagrams / Setting Sheets
HowStuffWorks Articles
Howstuffworks "How Manual Transmissions Work"
Howstuffworks "How Differentials Work"
Howstuffworks "What is the difference between a turbocharger and a supercharger on a car's engine?"
Howstuffworks "How Car Engines Work"
Howstuffworks "How Clutches Work"
Howstuffworks "How Car Computers Work"
Howstuffworks "How Fuel Injection Systems Work"
Howstuffworks "How Car Suspensions Work"
Howstuffworks "How Anti-Lock Brakes Work"
Howstuffworks "How Master Cylinders and Combination Valves Work"
Howstuffworks "What does it mean when a car has dual overhead cams?"
Howstuffworks "How Camshafts Work"
Howstuffworks "How Turbochargers Work"
Now obviously people out there will think that there are some links missing to this bible and that is obviously true. That is where you guys come in. If you think that there is a useful link that should be in here the please post it and I will add to it. The bigger this thing is the better.
Oh and to some of the sites you have to be a registered user (and some you even have to have a certain amount of posts like night-stalkers) before you can view the material. I wish that this wasn't the case because information should be readily available but I guess I see where they are coming from.
Well thanks for looking
-Tomek
edit: added a few more articles, primarily the 240tech page, some more ecu stuff and a lot of howstuffworks articles. hehe can never get enough of those...
Modified by sstomek at 1:16 AM 7/28/2006
Modified by sstomek at 1:17 AM 7/28/2006
Modified by sstomek at 5:56 PM 7/30/2006
My KAE-T Build Thread Updated 10/26/2007
CEO
03 G35C s/c, 93 S13 Vert KA-T, 72 240Z, 63 NL320, 67.5 SPL311, 69 and 70 SPL311s, '69 510
Phx, AZ
4-29-2002
Ummm, that information (99% of it) can all be found right here:
http://www.240sxTech.com
You've gotta remember, 240sx.org was around before 90% of those other sites, and most of that information originated with 240sx.org members.
Certainly if there's something we don't have, point it out and it'll be added.
Oh, and sites that make you register to see information? They SUCK.
Thanks Tomek!
TEAM NICO: 110,000 Nissan enthusiasts strong.
Add a link to NICOclub to your site!
...even the HITMAN is on MySpace
Stacey Lynn Childs 1970-2007... Love of my life, my best friend, Heaven's prettiest angel. I miss you so much.
sstomek
chicago il
8-3-2005
 « Re: (AZhitman)
Quote, originally posted by AZhitman »
Thanks Tomek!
thats why im posting this on the other sites, it may not help much here but it sure will on the other sites. Just trying to spread the information thats all. Thanks for bashin tho
--Tomek
CEO
Phx, AZ
4-29-2002
Ah, understood.
Wasn't my intention to bash - My bad, bro!
Feel free to add the link I included.
sstomek
chicago il
8-3-2005
 « Re: (AZhitman)
Ah, understood.
heh i over reacted, just that it took me liike 2 hours to get that stuff ready with the html code for the hyperlinks than you pwned my post up real good with that link hehe.
-Tomek
elwesso
Super Moderator
94 Q45t NICO Track Slut
Anderson and Angola IN
2-23-2003
 « Re: (sstomek)
Thanks for psoting that... Great way for 240 owners to get started!
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Joe, say Wes sent you.
Need a Nissan/Infiniti Mechanic around Indy OR Northern Indiana?? EMAIL ME!!!
NICO ECU's for sale
CEO
Phx, AZ
4-29-2002
Tomek - We can ALWAYS use some assistance drafting articles and compiling additional info for 240sxTech.com and NissanTech.com...
Any time you feel like cranking out some goodies, look at the Articles forum to get a feel for it and rock out.
Good to have you aboard bro.
sstomek
chicago il
8-3-2005
 « Re: The ULTIMATE 240SX Bible Volume 1 (sstomek)
some more links added, not too much time now so ill add the rest later...
-Tomek
iMurphy
Red 95 S14 SE Green 95 S14 SE
Logan OH
4-3-2006
Thanks a lot for all the information
Image exceeds 600x200 sig size limit
Make an offer...
sstomek
chicago il
8-3-2005
 « Re: The ULTIMATE 240SX Bible Volume 1 (iMurphy)
heh, no problem. I'm hoping to get more feedback in terms of links but I think i may have posted in the wrong section or something. Maybe i should try reposting in a different section...
-Tomek
PantherRacer
1992 Nissan 240SX. SR20
Orlando FL
4-24-2004
 « Re: (AZhitman)
sstomek? GREAT compilation
Hitman? how's that vented hood working out for you? create any problems when it rains? or do you just switch to the non-vented hood in that case lol.
Quote, originally posted by Soravia »
Beer makes you gay? I KNEW IT!
KA STUFF! BUY IT! SR STUFF! BUY IT!
"Whether it's a 100hp family car, or a 800hp monster, they're all murder weapons. When you understand that, you won't die."
vancouverbc
1991 240sx
langley
10-30-2003
 « Re: (PantherRacer)
batteryfaq.org is a good faq for batteries.
1989-1998 240sx TUTORIALS
FACTORY SERVICE MANUAL
Factory service manual2
Factory service manual 1989
Old FAQ
INSTALLS
Pictures of parts
kamikazeee
1991 240sx
Tinley Park Il
7-7-2006
Nice, that helped me a lot, I love the My240 website
Oh yeah....
...Mowisz po polsku?
sstomek
chicago il
8-3-2005
 « Re: The ULTIMATE 240SX Bible Volume 1 (kamikazeee)
czesc kamikazeee! tak mowim po polsku ale nigdy nie bylem w polskiem szkoly to nie pisam po polsku tak dobze. jeszcze uczym sie
See you live in tinley park, i have a friend close by you. did u buy ur 240 with cams and ecu already on? future plans?
-Tomek
kamikazeee
1991 240sx
Tinley Park Il
7-7-2006
what do u mean by cams and ecu allredy on?
What's ur friends name maybe I know him?
sstomek
chicago il
8-3-2005
lmfao, never mind that is based on ur post counnt, the thing below u. hehe im never on nico although it is crazy. his name is maczej.
-Tomek
kamikazeee
1991 240sx
Tinley Park Il
7-7-2006
No I don't think I know him, but maybe my brother does, well good sticky, oh and it;s Maciej
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
