sstomek »
https://forums.nicoclub.com/sstomek-u31323.html
Thu Jul 27, 2006 5:29 am
Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
240SX Tech Articles
^^^^don't forget that one, it was pointed out to me after i made this post...damn you AZHitman where were you when i needed you most^^^^
Electronics/ECUECU pinout diagrams.REWIRING YOUR IGNITION COILDistributor TimingRemoving speed limiter on 93 KA24DETDIY Ignition Mods for Better Spark Sr20det Ecu Fault Codes SR20DET ECU wiring diagram. FAQ: KA ECU # Glossory A long tutorial for tuning nissan's ECUs How-To: Chip Your ECU with Pictures (KA24E) Desoldering tipsBattery Relocation
Engine/Engine Info SETTING THE BASE TIMING ON THE DOHC PROPERLY How to build a KA24DE How to: S13 Oil pan removal DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE How-to: Build Your Own Oil Cooler S13 Red Top Vs. S13 Black Top - The differences DOHC Turbo For Dummies 240sx Engine Descriptions 240SX How To: Removing/Replacing your PS pump DIY: ITB's for your KA24DE Basics of engine management SR20DET Installation GuideEngine Knock (Detonation) Sensor Replacement (KA24DE)
Transmission How To: Convert from A/T to M/T How to Swap Your Auto Transmission for a 5-speed Changing transmission fluid / oil on s13 How to install paddle shift on an automatic 240SX 240sx Clutch and Flywheel SwapClutch Swap
Fuel REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's 240sx: Installing a Walbro Fuel Pump 240sx: Replacing Your KA24DE Fuel Injectors DIY: Installing an injector resistor box
Turbo HOW TO NEVER OVERBOOST AGAINBobby's DIY turbo oil feed/return lines install Turbo rebuild DIY
Suspension/Differential/Brakes Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential The Definitive 300ZX Brake Swap! Advanced Suspension Definitions Rear differential swaps for the 240sx Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion Rexbo's Guide To Brake Caliper RebuildingABS Removal
Interior Removing the S13 Door Panel Fabric Low-budget seat modification for S13 Re-covering Your S13 Glove Box DIY: Window regulator repair 5$ DIY: Dye That Ugly Carpet!!!!! W/picsCamera Mount
Exterior HOW TO: Repaint Headlight Housing (Black) DIY: Replacing Your Rusted Hatch 240sx Conversions - An Introduction Sleepy Eyes walkthru (VID) 240sx Vented Hood DIY Rust removal, Fiberglassing, and Body Filler DIY: Silvia Foglight Wiring
Factory Service Manuals/Diagrams Factory Service Manuals (FSMs) Your home for factory service manuals Parts Lists / Diagrams / Setting Sheets
HowStuffWorks Articles Howstuffworks "How Manual Transmissions Work" Howstuffworks "How Differentials Work" Howstuffworks "What is the difference between a turbocharger and a supercharger on a car's engine?" Howstuffworks "How Car Engines Work" Howstuffworks "How Clutches Work" Howstuffworks "How Car Computers Work" Howstuffworks "How Fuel Injection Systems Work" Howstuffworks "How Car Suspensions Work" Howstuffworks "How Anti-Lock Brakes Work" Howstuffworks "How Master Cylinders and Combination Valves Work" Howstuffworks "What does it mean when a car has dual overhead cams?" Howstuffworks "How Camshafts Work" Howstuffworks "How Turbochargers Work"
Now obviously people out there will think that there are some links missing to this bible and that is obviously true. That is where you guys come in. If you think that there is a useful link that should be in here the please post it and I will add to it. The bigger this thing is the better.
Oh and to some of the sites you have to be a registered user (and some you even have to have a certain amount of posts like night-stalkers) before you can view the material. I wish that this wasn't the case because information should be readily available but I guess I see where they are coming from.
Well thanks for looking-Tomek
edit: added a few more articles, primarily the 240tech page, some more ecu stuff and a lot of howstuffworks articles. hehe can never get enough of those...
Modified by sstomek at 1:16 AM 7/28/2006
Modified by sstomek at 1:17 AM 7/28/2006
Modified by sstomek at 5:56 PM 7/30/2006
