jetroy240 wrote:I believe the tach is receiving the rpm output signal from ecm & ecm receives the rpm input signal from crank engle sensor (distributor).
Actually the crank angle sensor is used for determining timing advance as well as other ECU functions. The crank angle sensor is usually mounted on the harmonic balancer, or the flywheel, where it car read the rotation of the crank. The distributor is mounted to the exhaust cam, and it reads the rotation of the cams.
The ECU receives its engine speed signal from the Cam angle sensor mounted in the distributor.
