jliaou »
https://forums.nicoclub.com/jliaou-u40690.html
Thu May 11, 2006 9:03 pm
I think I am the first to figure this problem out. About 1.5 years ago I ran into funny problem codes and this same stalling problem. I took it in 3 times to the same Nissan Dealership and they couldnt' figure it out. They kept giving me new "fixes" to try. I finally took it to an independent repair place and the guy figured it out. The Turbine Revolution Sensor on top of your Transmission is probably faulty and is leaking transmission fluid through it. Because of this leak, you will probably get funny problem codes down the road here. The transmission fluid flowd down the wiring harness of this sensor into a whole host of other harnesses, triggering Intake sensor issues, O2 sensor issues, etc. The stalling is due to the low transmission fluid. Check your transmission fluid. If it's low, then fill it up. Your problem should go away. Good luck. Let me know if this fixes the problem. BTW, the metal housing blocks the visibility of the transmission fluid on the ground until the leak gets severe, like mine did. Good luck and please repost to let me know.
~Blessings.
