CEO
Online
03 G35C s/c, 93 S13 Vert KA-T, 09 Cube, 72 240Z, 63 NL320, 67 WRL411, 67.5 SPL311, 69 / 70 SPL311s,
Phx, AZ
4-29-2002
Common problem with S13 autotrans. Seems to be worse in convertibles.I did a pan drop, filter change and new fluid (with a bottle of LucasOil trans treatment) and it seemed to make a big difference. Make sure to clean out the pan and remove the magnet and clean it well.
TEAM NICO: 128,000 Nissan enthusiasts strong.
NICOclub on Facebook AZhitman on MySpace Love it here? Add a link to NICOclub to your site!
oldbald_sarge
94 240sx conv
Monroe NC
12-18-2004
| « Re: (AZhitman) | 8:28 AM 2/5/2005 |
"seemed to make a difference" to what degree? Sometimes she runs like a dream, and sometimes more of a nightmare. No rhyme or reason, either. Has your transmission problem been fixed, or is it now more or less acceptable? Thanks for answering and giving me some help and options.
CEO
Online
Phx, AZ
4-29-2002
Nope, I spoke too soon.It accomplished nothing. Mine slips approx 10 minutes into driving it (from a cold start), and once it quits slipping, it drives fine (until it gets cold again, then starts all over again). Pulling the autotrans for a manual swap in 2 weeks, auto rebuild too expensive.
oldbald_sarge
94 240sx conv
Monroe NC
12-18-2004
| « Re: (AZhitman) | 1:02 PM 2/5/2005 |
Are you going to do the swap yourself, or are you going to hire someone? Let me know how that went.
CEO
Online
Phx, AZ
4-29-2002
Having the local guys over to help.We have some great "tech days"!
Eikon
Super Moderator
03 Infiniti I35, 96 240sx
Green Bay WI
4-24-2004
| « Re: (AZhitman) | 10:09 PM 2/5/2005 |
Hey AZ.. I know it's a lot of work.. but it would be very cool if you did a pictoral how-to guide for everyone else to follow in the future. I have seen other's do bits and pieces with pics, but never a real good step by step tranny swap guide. just an idea. Good luck with the swap. Nice to see another SHIFT---Convertible around.
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
 Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: 94 240 conv with AT shift problems (oldbald_sarge) | 9:03 AM 2/6/2005 |
| Quote, originally posted by oldbald_sarge » | | My 94 has intermittent shift problems. Seems she doesn't always want to upshift. Have to turn her off, restart, wait for the idle to drop to about 650 (ingear), and then she goes OK for a while. Is this a common problem with these cars? Other than that, she's my pride and joy. Had my mechanic look at it and he suggested some sensors/switches replacements. Hasn't helped yet. Help, please... |
I have a HB and it doess the exact same thing. Myself and others have been trying to figure it out on the tech. fourms but we have come up with little. We think it is electrical most likely a short or bad sensor. I don't think anyone has yet to figure it out, but the throtle positioning sensor and speed sensor might be part of the problem. Good luck!
Rockin the crooked H.
ncaa1969
1992 240sx convertible
Elizabeth City NC
2-6-2005
| « Re: (AZhitman) | 5:08 PM 2/8/2005 |
Same problem and symptoms here with 92 240 Conv. Only happens in a brief period about 7 to 10 minutes after a cold start or right away if the car has been shut down for about 20 minutes. Turning the key on and off clears it. I was thinking it was electrical but also have had the car drop back into and stay in first if I hit a sharp bump when just starting during that warming up period. But, if I start out real slowly it may not stick.Throttle position switch adjusted with minor improvement. Flush improved all other shifting characteristics but hasn't cured the base problem. I'll report any significant progress..........if it occurs.
CEO
Online
Phx, AZ
4-29-2002
Identical to my symptoms.Down to the exact timing....
smc2017
Fl
9-3-2003
| « Re: 94 240 conv with AT shift problems (oldbald_sarge) | 12:48 PM 2/16/2005 |
Had the same problem. I knocked a sensor loose when tightning my belts. Searched and searched and couldn't find it. I took it to an auto electric place and they fixed it for $35. I just put the 5 speed in a few months ago because the auto was nothing but problems. good luck.
MrUnderhill
240SX LE convertible
Prairie Village Kansas
2-22-2005
| « Re: 94 240 conv with AT shift problems (smc2017) | 3:30 PM 2/22/2005 |
I've got the same problem with my '92 conv with AT (started at about 145,000). I notice the problem after 5 - 10 minutes of driving, and it is always worse in warmer and more humid weather. Usually the problem occurs after waiting at a stop light and the transmission will not shift up. Occasionally the transmission will downshift while driving for no apparent reason and get stuck after that. The only ways I have found to remedy the problem while driving is to 1) stomp on the gas, 2) drive near red-line RPMs until the car shifts, or 3) if I can get the car up to 40 on a downslope the transmission will usually then shift up on its own. Any suggestions on a cheap fix would be most welcome.
CEO
Online
Phx, AZ
4-29-2002
Yep - Same as mine.I swapped to a 5-speed, thniking I had a bad trans.
240ROCKER
8-27-2003
| « Re: 94 240 conv with AT shift problems (smc2017) | 2:05 PM 2/23/2005 |
smc2017, When you say that you had a sensor loose and you had an auto electric place fix it for you, did this correct your AT shift problem or did you already have the 5 speed put in it when you had them fix your loose sensor? If this did fix your AT shift problem, which sensor was the culprit????? I have the exact same problem to the "T" as everyone else here in this forum with this auto tranny! I'll be waiting to hear back from you. Thanks!!!!! 240rocker
smc2017
Fl
9-3-2003
| « Re: 94 240 conv with AT shift problems (240ROCKER) | 5:18 AM 2/25/2005 |
I said sensor, but I think it was actually a wire into the wire harness. It did fix the shifting problem, but shortly after I ended up with a hard shift problem. Bad solenoids in the tranny were causing that. Fixed that and more crap happened. If you can put in a 5 speed you will be more happy. I did it 5 months ago, and I haven't had to fix anything since.
ncaa1969
Elizabeth City NC
2-6-2005
| « Re: 94 240 conv with AT shift problems (smc2017) | 5:52 PM 2/25/2005 |
I'm far from ready to declare success, but addition of a bottle of Lubegard has reduced the "hangup in first gear" problem from every trip to once in the last ten days.
240ROCKER
8-27-2003
| « Re: 94 240 conv with AT shift problems (ncaa1969) | 11:09 PM 2/25/2005 |
OK guys...I am determined to find out why this Auto tranny is behaving in this manner. There are just too many people on here that are having the same problems as we are. Here is what we know so far. The car seems to not want to shift into 2nd gear from first, sometime during the first 20 minutes of driving. It seems to happen more frequently when it's warmer outside and when there seems to be alot of humidity! It seems like the only way to temporarily correct this is to shut the car completely off. However, all we are doing when we do this is resetting the ECU back to default condition. That is why we are able to continue driving without the problem until the next time we drive after letting the car rest for about 20 minutes. I have also put in some tranny additive that is supposed to cool the tranny fluid temperature down about 10°. This worked for about two weeks, then it started happening again. This is definitely a heat/temperature problem based on these symtoms. This weekend, while driving my car, I'm going to hopefully get the car to exhibit this shift occurence and when it does, I am going to try and get the codes out of my ECU to see where it might be failing. I have had this problem for about two and a half years now and I have taken it to two different Nissan dealers and of course it wouldn't act up on them so I never got anywhere with them. One dealer did a $160 tranny flush and the other dealer charged me $35 to drive my car for an hour. I had a transmission shop look at it also and it never acted up for him either, but he suggested that maybe the TPS was bad so I replaced that too. Does anyone here who knows anything about the TCU think that maybe this could be the culprit? I work with electronics everyday and I know how picky some circuits can be when they go thru temperature extremes. What exactly does the TCU do? Does it actually tell the tranny when to shift gears? I found a place in Florida that repairs and sells these for around $250. Someone else also mentioned that maybe the 1st to 2nd solenoid in the tranny could be flaky. I talked to another transmission shop the other day and he told me that if it was the solenoid it wouldn't be bad at all to replace. All you have to do is drop the pan and check the solenoid and replace it if it's bad. OK guys these are the things that I'm looking at and as I find out more info I'll let you know. Oh...and I could very easily put a 5-speed in, but I really want to know why this is happening to our Auto tranny's. I am determined to find out. I'll keep ya posted and anymore info you can offer would be great too! Thanks!!! 240ROCKER
240ROCKER
8-27-2003
| « A Question For Those Of You Who Have Had This AT Shift Problem? | 8:52 AM 2/28/2005 |
Have any of you had to replace your radiator before you started having the shift problem? If so, did you buy an OEM or aftermarket radiator?
smc2017
Fl
9-3-2003
| « Re: A Question For Those Of You Who Have Had This AT Shift Problem? (240ROCKER) | 10:07 AM 2/28/2005 |
I replaced my radiator, but not because of the shift problem. Just bought one at NAPA, was a direct replacement. Make sure you bleed the hell out of it, or you will have overheating up the ***.
240ROCKER
8-27-2003
| « Re: A Question For Those Of You Who Have Had This AT Shift Problem? (smc2017) | 12:38 PM 2/28/2005 |
Nah...I'm not saying I replaced my radiator due the shift problem. I'm saying that when I had a problem a couple of years ago with my car overheating that I replaced the radiator with an aftermarket one and ever since then I have had this intermittent shift problem! The overheating problem was fixed, but the shift problem was created.!  240ROCKER
240ROCKER
8-27-2003
| « Has Anyone Red-Lined While Trying To Shift? (240ROCKER) | 1:08 PM 2/28/2005 |
Has anyone who has had this shift problem ever red-lined it to see if it will shift into second?Another question I have is if I take off manually in first gear will the car automatically shift into second as it approaches red-line even though I'm in first?
CEO
Online
Phx, AZ
4-29-2002
No.Mine would rev to the rev limiter (I feared damaging the motor). Manually leaving the car in first will hold it there.
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: Has Anyone Red-Lined While Trying To Shift? (240ROCKER) | 9:24 PM 2/28/2005 |
I have redlined mine several times seeing if I could get the tranny to shift, but it didn't work. I don't recommend it. I have been taking mine to shops in my area, but no one knows what is the matter with it. Recently I had an episode where my car didn't shift. I shut it off and restarted it, but this didn't work. I tried again and got it to shift. Ever since that bad episode it shifts kinda hard and makes a whining noise at low speeds. I am about ready to have the transmission rebuilt. I guess 2 years of this problem has taken it's toll on the car. I wish I could figure it out!
240ROCKER
8-27-2003
| « Re: 94 240 conv with AT shift problems | 7:58 AM 3/1/2005 |
Well guys I found out something interesting about having your automatic transmission rebuilt. Apparently, when you opt to have your automatic transmission rebuilt, this does not include rebuilding the "valve body" which is the brain of the transmission. Several people have posted on here and on other places on the internet who decided to rebuild their transmissions only to find out that they still had the shift problem. What a bummer to know that you spent all that money for a rebuild and it didn't actually fix the problem.The valve body has all sorts of control valves and springs and is a very expensive part to replace, which is why most tranny shops don't rebuild or replace these. I have learned that more than likely I have a stuck control valve in the valve body and the reason that I normally don't have a problem in colder weather (50° or lower) is because there is more pressure being built up in the valve body to compensate for the colder temps. and when it's warmer weather, the pressure isn't as high and therefore one of the control valves that pertains to the 1st to 2nd shift is getting stuck. I was told that an additive called "Transmedic" might unstick this valve. It will take about two to three weeks to really get into the system, but that it might keep that control valve from sticking. What are your thoughts on this? 240ROCKER
Modified by 240ROCKER at 1:03 PM 3/1/2005
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: 94 240 conv with AT shift problems (240ROCKER) | 4:42 PM 3/1/2005 |
I haven't heard that before, but it make sense. Thank you for the help. The thing is, my car repeatively has issues shifting into 4th also. Is there one valve body, or are there multiple ones that control different trans functions?
240ROCKER
8-27-2003
| « Re: 94 240 conv with AT shift problems (2the40) | 5:49 PM 3/1/2005 |
There is only one valve body, but there are lots of tiny valves and springs that control the following: Torque Converter relief valve, Pressure regulator valve, Pressure modifier valve, 4-2 Sequence valve, 4-2 relay valve, Overrun clutch control valve, Overrun clutch reducing valve, Shuttle Shift valve, Lock-up control valve, Pilot valve, Accumulator control valve and these are just the valves in the top body of the valve body. The lower body of the valve body has these valves in it: Servo charger valve, 3-2 timing valve, 1st reducing valve, Manual valve, Modifier accumulator valve. So as you can see there are a bunch of valves in this very intricate part and this is more than likely the cause of our shift problems. One of these valves is getting stuck and not operating properly. I'm going to try this Transmedic additive made by GUNK and I'm going to see if this fixes my problem. I will give it a few weeks and see what happens. 240ROCKER
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: 94 240 conv with AT shift problems (240ROCKER) | 6:24 PM 3/1/2005 |
Wow, the valve body does have a lot of parts. I think I will try the additive too.Thanks for the info!
MrUnderhill
2-22-2005
| « Re: 94 240 conv with AT shift problems (2the40) | 8:49 AM 3/2/2005 |
I tried Transmedic about 18 months ago and I had the same experience as the person who posted about using Lubeguard - it might have helped for a few days but soon the transmission was up to its old tricks again. I've still got half the bottle on the shelf in the garage, so maybe I didn't get enough into the system, but I didn't have much luck with it as a permanent cure.I'm curious to know if 240Rocker's ECU codes have yielded any clues as to what the problem(s) might be...
240ROCKER
8-27-2003
| « Re: 94 240 conv with AT shift problems (MrUnderhill) | 11:00 AM 3/2/2005 |
Well...yesterday the temperature outside was 45° and I had the shift problem while driving. As I have stated earlier that this problem doesn't usually happen in colder weather, but it did yesterday. Anyway, I quickly pulled over to a side street and turned my car off and looked at the ECU code and there wasn't any failure code whatsoever. I had a '55' which is a code for everything is fine!  It is my understanding that you need to pour the entire bottle of Transmedic in your tranny and wait a good two to three weeks to get in your system. Has anyone used the new Dexron III in their auto tranny's yet? I have also read on other forums that this might possibly fix tranny problems as well. There are so many possible solutions out there. I just wish we could find one that everyone is in agreement with!!!! I'm still determined to get to the bottom of this! 240ROCKER
Modified by 240ROCKER at 1:10 PM 3/2/2005
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: 94 240 conv with AT shift problems (240ROCKER) | 2:13 PM 3/2/2005 |
I tried that Dexron III Mercon for my last fluid change. I also used Seafoam Trans Tune just before I changed the fluid and filter. I noticed an incredible difference in shifting for about 20 minutes after, but then it started to screw up again. The only thing I might have done wrong was not leaving the Seafoam in the transmission long enough.
240ROCKER
8-27-2003
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 7:40 AM 3/11/2005 |
Here is a little bit of an update on my quest to find out why our auto tranny's are behaving in this manner. First off, I removed the kick panel so I could get at the ECU so that I could see if it would give me an error code. It did not. It gave me a code of '55', which means no error. Next, I went and talked to a auto tranny specialist here and we talked about this shift problem in great detail for over an hour. He was very informative. He seems to think that this is definitely an electrical problem and not a mechanical one because of the fact that it always happens during the first 5 to 10 minutes of a cold start. He advised me to splice an LED on the wire that goes to the Shift solenoid for D1 to D2 (this is pin 6 of the TCU). I believe the service manual calls it Solenoid "A". Tie the other end of the LED to ground. Make the wires long enough for the LED to be in plain site while driving so you can see it for this test. When the car is operating correctly, and the car is still in first gear the LED will be 'ON' and when it shifts to second gear, the LED should turn 'OFF'. Now, if the car doesn't shift into second and you are above 37 MPH, look at the LED as it should be off. If the LED is 'ON' at this point, then the TCU is bad. If it is 'OFF'and your car hasn't shifted yet into second, then more than likely you will have a bad shift solenoid for D1 to D2. I told him that I had read that on other forums that replacing the valve body was a fix that some people had tried and worked. He told me that the reason that was probably a fix is because more than likely, when the valve body was replaced, so was the solenoid because it is attached to the valve body. The reason that we are seeing this intermittent shift occur during the first to second shift interval is because this solenoid is used more than the other solenoids. However, in time the other gears will more than likely behave in this manner, which means that the other solenoids will eventually go bad too. I haven't hooked up the LED yet. The TCU is a little bit further up in the dash and so I really haven't had time yet to unbolt it from the frame. I'm doing that this weekend, so when I get the results of the LED test I'll let you know. If the LED is 'OFF' and the car doesn't shift, I'm taking the car to my tranny specialist and he is going to remove the D1 to D2 solenoid and test it in a heat exchanger to see if it is operating properly. I'll let everyone know as soon as I know...! 240ROCKER
guyaverage
240sx Convertible
cincinnati Ohio
2-19-2004
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 12:07 PM 3/11/2005 |
^^ Great information, definitely let us know what happens.
2the40
Tiburon GT
Knoxville TN
12-13-2004
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 3:31 PM 3/11/2005 |
240Rocker... you're my favorite.Great info!
ncaa1969
Elizabeth City NC
2-6-2005
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 2:46 PM 3/12/2005 |
240Rocker (and all interested parties....) I set up the LED's as recommended. I actually used two, one for Solenoid "A" and one for Solenoid "B".At startup from cold, the transmission shifted properly and the LED's behaved properly, that is: A+B lit for first gear, B only for second, none for third, and A only for overdrive. I stopped and started until it hung up in first gear, staying in first all the way to redline (where I backed off) without shifting. During this hangup, both LED's for A+B stayed lit, indicating that the TCU was telling the transmission to stay in first gear. Unfortunately the hang up only occured once and the next (and all following) stop and start operations shifted normally and the LED's behaved normally. I intend to try this again tomorrow once everything has cooled down. I would like to replicate the "hang up for a while but then shift" pattern I sometimes get. But by your mechanic's analysis this would point to a bad TCU. TCU's sound expensive, so there is one more thing I am checking. The transmission has a fluid temperature sensor in the sump, a resistor whose resistance drops as the fluid temperature rises. I measured the resistance when cold (65 degrees in the garage) and it was 2560 ohms versus the manual's standard of 2500 for 68 degrees. I took another reading when warmed up and got about 600 ohms (no range is given in the service manual). I will try to rig up a way to measure this resistance on the fly so I can watch the multimeter to see if the resistance drops smoothly as the fluid warms up. Not sure what I'm looking for but I would certainly expect the change in resistance to be smooth. We'll see. I sure would like the temperature sensor to be the culprit since it looks cheaper and is easily changed (drop the pan and it is right there.) I wish I knew the computer logic (how it integrates throttle position, RPM, fluid temperature, and probably some other inputs) to decide when to deactivate Solenoid "A". I'll look for your results and report mine when available. But in the meantime we might start searching parts stores and junkyards for replacement TCU's............
240ROCKER
8-27-2003
| « Re: UPDATE: 94 240 conv with AT shift problems (ncaa1969) | 5:32 PM 3/12/2005 |
Hey there ncaa1969, I finally got my LED hooked up this afternoon to the TCU pin 6. Did you have a lot of trouble trying to get at your TCU. The bottom screw was real easy to get, but the top one was behind the Blower Motor Housing. I had a heck of a time trying to get that thing out. I was finally able to loosen up the heater coil housing enough to wedge the Blower Motor Housing out of the way. I haven't has a chance yet to drive it around yet, I'm gonna do that in a few minutes. I'll report back here when I get some data. The fluid temperature sensor is an interesting theory too. I would think that that is a huge delta from 600 ohms to 2.5K. Maybe that could be our problem. I put in some of that tranny additive that is supposed to bring the fluid down about 10° and when I did that, I didn't have any problems for nearly two weeks. Interesting....240ROCKER
240ROCKER
8-27-2003
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 6:14 PM 3/12/2005 |
Well...I just returned from driving my car for a few miles and guess what happened? My car started doing the intermittent shift from first to second and the LED remained on, which means the tranny didn't get the signal to shift to second gear. I am going to drive it some more tomorrow and see if I can duplicate these results. It looks liike it might be the TCU.I have read here and on other forums that they changed the TCU out and still had the same problem. I'm wondering if people got confused, and changed out the ECU, thinking that they were changing out the TCU. I know I made that mistake at first when I started looking for pin 6 and realized that the color of wire was not what the service manual indicated. The ECU is the very first box that you see when you remove the passenger side kick panel. The TCU is further up into the firewall behind the blower motor. It ain't no picnic to get out either!!!!! lol I'll post back again tomorrow after driving it a while. 240ROCKER
ncaa1969
Elizabeth City NC
2-6-2005
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 5:26 AM 3/13/2005 |
240Rocker, I didn't make the connections at the TCU so I haven't fought with removal yet. I connected all at the terminal connector under the hood (bottom of three connectors by the fuse box).I took resistance readings on the fluid temperature sensor at hourly intervals as the fluid cooled down. Resistance seemed to climb smoothly back up to 2.5K ohm range. So I'm doubting my hopeful theory of a bad fluid temp sensor. But.......if the problem develops when the resistance drops to a certain level you could splice in a resistor and keep the signal from ever dropping into that range. Not sure what that would do to shifting patterns however. I'll mull this over some more......... Of course there is one very easy fix that won't cure the problem but would make it easy to overcome. You could put an interupt switch on the power supply to the TCU. At every hangup just flip the switch on and off and reset the computer. Same cure as turning the engine off and back on but quicker and easier on the starter. The saga continues.
240ROCKER
8-27-2003
| « Re: UPDATE: 94 240 conv with AT shift problems (ncaa1969) | 4:32 PM 3/24/2005 |
Well...here is an update for everyone on my quest to solve this intermittent transmission problem. First off, it is not the TCU. I was able to buy one that was rebuilt and guaranteed to work and if it didn't I would only be charged a $25 restocking fee. It was a gamble, but I went for it anyway. After I received it, I put in and after afew short minutes the problem reared it's ugly head. Sent it back and got my money back. Next, I took the car to my trusted transmission shop and he told me from the beginning that he really thought that it was electrical and not mechanical. After doing the LED test that I did, this just proved that the transmission isn't getting the command to shift to second. By me putting in a remanufactured TCU that pretty much rules out a bad TCU.The transmission shop had it for three days tring to get it to act up and of course it didn't. In fact, he said that this tranny is in very good shape to have 149K miles on it. He said that the tranny is shifting great in all gears and that he couldn't detect any malfunction whatsoever and he has been in the business for thirty some odd years and he knows when a tranny is not behaving properly. He suggested for me to put an LED on the other solenoid as well and see what state it is in when the shift problem occurs. I noticed that ncaa1969 has already done that and he reported that both LED's were on at the same time which means the tranny doesn't know what to do so it stays in 'limp' mode. This is where the tranny will still run but only in first gear. My tranny specialist said that if both LED's were on, than there is some bleed over from one solenoid to another which is caused by one of three things. First, if when the problem occurs glance at the speedometer and see if there is some erratic movement back and forth of the speedometer needle. If there is erratic back and forth movement then the Speed Sensor is faulty. It is mounted on the side of the tranny. Second, if the speedometer is OK, then there is a wire somewhere in the main harness that has some of its insulation rubbed off and is somehow shorting to ground or a wire that goes to ground is loose. The third thing he said to check is all the interconnects between the TCU, ECU and tranny. It's very possible since these interconnects are right near the battery that there is some corrosion that has gotten inside one of these connectors causing intermittent connection. He suggested pulling them all off one at a time and give them a real good cleaning with contact cleaner. My tranny specialist told me that he is nearly 100% sure that the tranny itself is just fine and for me to start looking electrically. I told everyone from the beginning that I was going to find out what was causing this and I'm just about there. This guy spent nearly four hours with me on this problem the last few days and I asked him how much I owed him for his time and he told me to "put my money away", that he was very happy to help me out as he wants to know what is causing the problem too so that he can file it in his database. 240ROCKER
ncaa1969
Elizabeth City NC
2-6-2005
| « Re: UPDATE: 94 240 conv with AT shift problems (240ROCKER) | 3:25 PM 3/25/2005 |
240rocker, Thanks for the update and news that changing the TCU did no good. BTW, having both solenoids on is proper for first gear per the service manual, not a limp mode. A & B on equals first gear, B only equals second, none on equals third and A only equals fourth/overdrive.I've been monitoring the voltage output of the fluid temperature sensor as the car warms up. The voltage drops normally from 1.6 volts to .48 volts and the hang up in first gear happens when the voltage is in the .75 to .8 volt range. Still no idea what that means, except that the hang up occurs at that voltage signal and accompanying fluid temperature. I'll try the contact cleaner on all connections. Can't hurt. Might help. I have no flicker of the speedometer, perhaps ruling out the speed sensor.
maik21
240sx Coupe 5.0 90
Obregon Sonora
2-8-2004
i have the same problem with my automatic transmision (s13) .... my car dont up shift.... i put into the "d" and it run fine, but dont upshift to "2nd" ; and i have to run in 1st near to redline and depress gas and it shift to 3th, but 2nd never work.... i did a tcu diagnostic and the overdrive light told me that the trans is fine. the solenoids a and b are in 24 ohms .... i disconect the trans arnes from the motor bay and put a 0 volts into solenoid a and 10volts into solenoid b, and no changes... i think that something is stuck!!! what i do to resolve this problem?? transmedic ??
Ford 5.0 explorer swap, t5 , long headers, edelbrock torker II intake, edelbrock 600cfm carb. =)
| First 1 2 3 4 5 > Last |
