transmission
okinawa drift
Car: 89 240sx SOHCoupe
would a transmission from a KA engine fit an SR engine?
or do you have to buy a completely new transmission if you got a sr swap?
FSUDrifter
Car: trying to decide on one...
most swaps come with the sr transmission which fits perfectly in all s13's and s14's
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's rare to get a motorset without a trans. But in the rare case, you can use a KA trans, but the bellhousing bolt pattern is different. So to use the transmission, you have to swap out the bellhousings.
I've seen SR transes on eBay off and on, but the price is always hit or miss I think.
Also, the transmissions are pretty much swappable between generations. I've put an S13 trans in an s14 chassis, and I mated an S14 KA gearbox and trans case to an S13 bellhousing.
okinawa drift
ohh okk cuz im buying a 90 240sx coupe its REALLY clean , but its an auto, but im planning on doing an sr swap when i have the money but in the mean time i'lll just swap the transmission, i didnt wanna buy a transmission that didnt fit the sr, but i didnt know sr swaps came with one, haha thank guys
notslow
Car: Nissan Sileighty
dood, if you havent bought your auto yet I would say hold out.
From somebody who has owned both an auto and standard KA series (auto was KA24DE, and manual KA24E) and now the SR20 I would say wait till you can find a decent manual, especially if you have little sr20 thought bubbles above your head. Doing an auto to manual swap is just an extra expense and stress that you don't want to have to deal with. It can be done, but why wouldn't you avoid it if you could?
Besides all that, my DOHC automatic had all the basics (Intake/Header/Exhaust, spark plugs/wires etc.) and it still didnt have much gain (if any) on the manual before the engine swap.
Stick FTW!
okinawa drift
notslow wrote:dood, if you havent bought your auto yet I would say hold out.
Stick FTW!
well, this is prollly the CLEANEST coupe i have seen in oregon, and my grandpa is a mechanic so he prolly would help tons! but heres a thread, 240's here in oregon arent to great, this one dude was selling a stock 240 coupe for 3500, but it was manny but too much..
zerothread?id=242466
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Oh man am I glad I saw this thread. My SR transmission just took a dump on me and I recently got a 240SX as a parts car. I was wondering it I could use the KA transmission in it.
So all I have to do is swap the bellhousing and it will fit right?Woo, life isn't that bad. Or is it?
Oh, what happened to my SR transmission?
It would grind slightly going into fifth no matter what, and it wouldn't go into reverse. I'd have to pump the clutch pedal and yank it into reverse.so last night I'm cruising and I go into fifth, come off the clutch and car revs up. no fifth gear. I guess reverse went out the same time.This morning I go to back out of the carport, put it in reverse, car revs, no reverse. So I put it into first, let out the pedal, car stalls. put it in neutral, come off the pedal, car stalls. Put it back in first, rev it up, let off the pedal super slow, car stalls. CRAP.
notslow
sounds like she has gone to JDM transmission heaven.
That sucks man. I have heard of people using the KA transmission but never actually seen it done. I was also told that just the bell housing needed to be swapped.
tiger
im in the middle of swapping bellhousings for my sr transmission.. i'm in the process of trying to get the KA one off.... I have undone all bolts that connect the housing to the actual transmission... taken off the C clip and snap ring from the shaft.. now what the heck do I do.. I have pried it loose but it seems like it won't come all the way off.. have I missed something.. ?
eliterit
Car: pignose
as long as u took the big c clip off of the main shaft that comes out of the transmission, it should just pry right off.
tiger
dang it I was just being a sissy and not jiggling it hard enough.. I got the case seperated and pried and then it came out.. thanks!!!
oh and BTW, I just put my SR bellhousing on the KA transmission.. ehe everything is good so far.. now times to puts it on the Block!
