brandonlgilbert »
https://forums.nicoclub.com/brandonlgilbert-u37593.html
Sun Feb 25, 2007 4:06 pm
OK guys this is what I have. 1996 240sx SE with a Zenki SR20DET and 5spd. I have the B&M short shifter and SPEC stage 2 clutch.
The problem: Today I was a stop sign coming home from washing the car. I started out kinda slow and at around 20mph gave it full throttle. Since I have old worn out 205/55/16 on stock rims, it spun some. Took it up to around 6800 and shifted to 2nd. It spun a little, and again I took it up to around 6800 and shifted to 3rd. Tires chirped and once more went to 6800. As soon as I went for 4th, the shifter felt, for lack of better description, like a stick in a bucket. It was just kinda flopping around and I couldn't "feel" where the gears were. So I pressed the clutch in and coasted down the street to my house. Once in my driveway, I discovered that it was still in gear. I couldn't tell by the location of the shifter which gear I was in. Since it tried to die when I let out on the clutch, I figured it was still in 4th. I had to get it into neutral so I could push it into the garage. I had to pick up and push down on the shifter and wiggle it left and right, up and down and try to let out on the clutch pedal to figure out if it was in neutral. Finally after 15 minutes of doing this I got it into neutral.
So, anyway, that is my situation. Any ideas what might have gone wrong? The swap and clutch may have a total of 4000 miles on it since putting it in the car.
My buddy said maybe an input shaft problem. ????
Help me out here guys. I know you all are the experts.
I'm good at 2 things: making a lot of noise and breaking sh*t so any help is greatly appreciated.
