Transmission getting replaced...new clutch ordered
fbpem1
joe603 wrote:So I talked with the service manager...
no budging on either charge. They must be losing $$ on warranty work. Oh well...I didn't really want to spend a grand on the car right before Christmas...but that's life.
warranty pays ~2.5 to put a clutch in, so yes we do loose our *** on warranty work badly.
About the car competing with bmw and the likes of, talk to some people that work there they have thier fair share of problems as well, and can be d!ck about warranty, infiniti/nissan are the two most warranty friendly brands out there from what i have seen both in owning differant cars as a consumer and as a tech working for infiniti/nissan for as long as i have.
Jacko...there will be issues doing two clutches under warrranty they keep a CLOSE eye on that trust me and i doubt they are going to want to risk thier *** for doing another clutch since it is a wearable part. I understand you don't care about paying but i would pay anyhow and not expect another clutch under warranty unless they can show it was defective but with a wearable part thats very very very hard to do, ask me how i know i got in trouble for it by corperate back in 2004
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Yeah.... especially the way Jacko Flogs it
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
How Can you tell if the clutch is going?
Does is that where the chatter comes from?
DJ
BrandAidDesignG35
If you're engine RPM's rise, and your speed does not, you have a bad clutch.
If you have a lot of chatter in lower rpms, this could be due to uneven flywheel wear, glazing, etc. or poor engine mounts...
My Altima chatters under 2K... I have heard from my mechanic, I may need to re-plane the flywheel to correct this... provided it's not my engine mounts.
joe603
Car: 2014 Durango R/T
sometimes...the easiest way to tell if a clutch is bad is to test for slippage. Put it into 6th gear and lug the engine...if the RPMS go up, but the car doesn't go faster, your clutch is slipping.
The chatter is a multitude of things. The primary culprit is the flywheel. On a worn clutch/flywheel it has too much play and can make a lot of noise. The flywheel/clutch/input shaft design also makes an impact on noise. Infiniti tried to suppress the noise by using a dual-mass flywheel.
Tampa G35 Sedan 6MT
Do they ever fix the chatter if my clutch is good?
I can put the car in 6th and floor it and it goes! I Don't think I have any slippage in my clutch. But I have a lot of chatter! I want that gone!
DJ
joe603
If you have the OEM clutch and are still getting a lot of chatter it could be a loose flywheel bolt. Take it to the dealer.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Tampa G35 Sedan 6MT wrote:How Can you tell if the clutch is going?
DJ
I know from two factors:
1) Dealership told me so when my engine was replaced.
2) I did a slight S L I G H T mishift (gave it gas before the clutch was completely out) and the clutch slipped like all hell. Then the dreaded smell. I used to only smell the clutch when I was d!ck around (rarely). Now I'm smelling it more often.
The high gear test failed with my clutch. I know it's going bad, but it still grabs and stalls if I put it in 6th and let it in (slowly).
joe603
Ohhh... as a side note, when I talked with the service manager I mentioned how I thought it was unfortunate that the transmission needed to be replaced on a modern car, but at least it wasn't the engine. He then asked if I slow the car down by downshifting. I said no, I use the brakes. He said that's why I don't have oil consumption...when you downshift it supposedly "sucks" the oil in. I don't know enough about it to respond to that intelligently...but I was pretty sure that the bad engines have ring issues.
Sentientbydesign
96 I30 - Sold
They do have ring issues, but the dealers seem to know/believe that the consumption itself is caused by engine braking. I'm assuming the logic is that you'd have a vacuum on the combustion side of the ring.
fbpem1
Sentientbydesign wrote:They do have ring issues, but the dealers seem to know/believe that the consumption itself is caused by engine braking. I'm assuming the logic is that you'd have a vacuum on the combustion side of the ring.
thats a very old theory, not the case sorry.
C-Kwik
So long as they are just charging you the labor to remove the old clutch and install a new clutch (perhaps with a flywheel resurfacing if it can be done) then I'd just pay to have the clutch done. You would have to pay a lot more if they had to remove the transmission on your dime to replace the clutch.
joe603 wrote:Here's the clutch I'm getting:
http://www.forgedperformance.c...age=1
It's a "stage 4" clutch that will handle up to 500HP. So if I do go FI, it will handle it. The guys at Forged Performance recommended the kit over the JWT one. They say that this one will not chatter as bad as the others ones either.
Do you actually have a need for such an aggressive clutch? The take up on a clutch like that is generally aggressive and the metallic surface is likely to wear out the flywheel and pressure plate sooner. I'd imagine the organic liners in a clutch designed for the VQ will be able to handle near stock power just fine. There are plenty of companies that make organic clutch kits that are designed for higher clamping loads as well.
Also, if the photo in that link is accurate, then its a sprung hub on the clutch disc. My understanding is the VQ's disc is solid and torsional vibrations are absorbed by the dual mass flywheel. If both are sprung, then it's likely you will have to compress both sets of springs before any measurable amount of torque can be applied to the drivetrain. I'd speculate it might feel sloppy. Though, it could be a reason less drivetrain chatter is heard...
fbpem1 wrote:This is the kind of attitude i HATE i think its appauling that customers think everything is the factorys fault YOU have to take SOME responsibility for actions taken with the car and what you have done with it and to it. If you can't do that you need to grow up.
That depends. Consider the G was branded as a performance car. It should be able to handle a reasonable amount of spiritied driving. To say a customer is arbitrarily at fault for a mechanical failure is absurd. If you were the one making the repairs and you saw evidence of abuse and such, then fine. But you are not making the repairs on this car, nor do you have the parts of this car sitting on front of you to be evaluated. And while its not my place to tell you how to do your job, conmsider that without us consumers, you would have no job at your current place of employment. Not to mention, if the car was built in such a manner that it could never break down, you'ld be out of a job.
fbpem1 wrote:40k car....needs trans....what about 200k+ ferrari's that blow the engine at 3 thousand miles and you don't have a warranty. just becuase the car costs 40k dosn't mean its bulletproof dosn't mean its going to take everything you throw at it. you have a mix of a sports car (i also use that term loosley) and a luxery car. So that trans is NOT the strongest out there it will NOT take everything you throw at it esspecially if you flat foot it, banging gears all the time, its going to happen you gotta pay to play i blew my trans in my car and i was half expecting to pay for it or split cost with the dealer since it was suspected abuse i admitted to them that i dog the car everynow and again but since i was open and honest with them they didn't care pretty much and rebuilt mine under warranty, keep in mind this was at 13,000 miles, and the trans i am talking about costs considerably more money than a G35 trans, about $6,500 out the door parts alone with a new trans.
That's a lot of assumptions you are making.
fbpem1 wrote:I have a theory on the exhaust and heres why i think they are charging you since you have a aftermarket exhaust i don't knw what kind it is i don't know if its an H pipe or a Y pipe but you know aftermarket stuff can break when you take it off maybe your bolts are all crap and maybe they will break off in your cat (if you have them) and they have to be drilled out thats a pain in the ***. The dealer is covering THIER *** because we are much more worried about corperate being pissed off at us than 1 customer, becuase a wearable item (clutch) needs to be replaced and your trans is shot dosn't mean the product is crap might also mean that you don't drive correctly.
So why not write a disclaimer into the work order such that IF something goes wrong with that part due to no error on the part of the tech, then the customer is charged for any additional labor and parts required to complete the job? My thought is the dealer is trying to make a quick buck in hoping that the customer will be to naive to realize that the labor is the same either way. If it wasn't, why wouldn't they simply point that out to begin with and charge the appropriate amount of labor over what Nissan allows?
fbpem1 wrote:i know this came off quite d*ckish but oh well this attitude in a customer i can't stand they feel entilted to something and refuse to pay when it could be THIER fault. I just had this conversation with a customer today and when he saw things from my point of view and the dealers and compared them to his own, wow low and behold HE was the one being unreasonable.
Each warranty issue is case by case. Treat it as such. Lumping everyone into one category is basically making a huge assumption. In one case it could be the owner's fault. Then again, it may not be. Perhaps you just needed to vent about your own experiences, but you imply Joe was the cause (at least partly) without being able to make a first hand assessment of the situation. Unless you are some kind of a super tech who can diagnose root causes of failures over the internet. Not to say that you can't make generalizations, but you appear to be targetting a specific person in a specific scenario.
Rings should be sealing regardless. Under vacuum, the rings would be pulled by the vacuum against the cylinder walls and the top of the ring land. Assuming the ring to cyulinder wall seal is good, then there should not be any excessive oil consumtion occuring due to vacuum alone. High vacuum will of course pull oil through a bad seal, but it shouldn't be a cause of the failure itself.
Sentientbydesign
96 I30 - Sold
I'm glad you enjoy wasting your time. Either tell us what it is or shut up!
fbpem1
C-Kwik wrote:So long as they are just charging you the labor to remove the old clutch and install a new clutch (perhaps with a flywheel resurfacing if it can be done) then I'd just pay to have the clutch done. You would have to pay a lot more if they had to remove the transmission on your dime to replace the clutch.
dual mass are not resurfacable most you can do is hit with a wizz wheel but the springs inside are what is the worst of it
C-Kwik wrote:So why not write a disclaimer into the work order such that IF something goes wrong with that part due to no error on the part of the tech, then the customer is charged for any additional labor and parts required to complete the job? My thought is the dealer is trying to make a quick buck in hoping that the customer will be to naive to realize that the labor is the same either way. If it wasn't, why wouldn't they simply point that out to begin with and charge the appropriate amount of labor over what Nissan allows?
most dealers have a policy for customers they don't know dont have a relationship with the ASM must get checkout time or diag time or some sort of tear down time, i don't think its unreasonable to ask for a couple hundred bucks up front for just in case, your not paying the money now just approving it, i do that all the time and i will tell you this if said thing comes apart or whatever easy i wave the fee dosn't matter. Always have something up front, heres a ****ty analogy if you were to sell something to someone you don't know would it be ok to give them product let them try it out and they pay you tomorrow? no it wouldn't be authorization must be made for tear down work.
Me personally i don't care what the car has aftermarket aside from test pipes of hfc i will look past just about everything else in regards to warranty work.
C-Kwik wrote:Each warranty issue is case by case. Treat it as such. Lumping everyone into one category is basically making a huge assumption. In one case it could be the owner's fault. Then again, it may not be. Perhaps you just needed to vent about your own experiences, but you imply Joe was the cause (at least partly) without being able to make a first hand assessment of the situation. Unless you are some kind of a super tech who can diagnose root causes of failures over the internet. Not to say that you can't make generalizations, but you appear to be targetting a specific person in a specific scenario.
i don't believe i made any assumption or lumped anyone into a catagory i was simply stating what could happen or what may happen or what might have happen, a d!ck way of playing devils advocate maybe...No i can't make a first hand diagnosis but i can base all my experiance with g and z trans issues into effect and from most i have pulled down with some sort of mods the clutch's have been in worse shape than the ones with more miles and no mods. Its a fact the car is driven harder your not going to put exhaust and whatever else on the car and then putt around like a grandma just dosn't happen your gonna open it up your going to have fun with it. Like i said though sometimes you gotta pay to play thats a fact of modifying anything.
C-Kwik wrote:Rings should be sealing regardless. Under vacuum, the rings would be pulled by the vacuum against the cylinder walls and the top of the ring land. Assuming the ring to cyulinder wall seal is good, then there should not be any excessive oil consumtion occuring due to vacuum alone. High vacuum will of course pull oil through a bad seal, but it shouldn't be a cause of the failure itself.
if you ahve looked at a motor that has bad OC on a vq which is needed the replacement motor smokes all the time, its not the rings trust me.
Now as for Joe's perticular motor no OC issues, thats good question though he has a coupe well there is a vin range for those early 05's and late 07's and maybe a couple others in between don't get the motor its right on the tsb since they don't have a problem all sedans are a potential problem though in the 05-06 range.
fbpem1
i do enjoy wasting my time i think you do as well, your kind of fiesty today i think you need to be put outside for a bit
Tampa G35 Sedan 6MT
fbpem1: Try to be nice or
fbpem1
damnit my post was too long i guess, i lost a lot of it. Long and short of it is...vq's have a sprung hub clutch disc.
dual mass flywheels and hard driving are bad since dual mass flywheels hold torque in and release it say on a flat foot shift you shock the drivetrain badly and the flywheel which is sopposed to be a comfort thing works against you and unleashes the stored torque after the initial shocks come in you don't feel it but its there since power was stopped then came then came agian.
Tampa G35 Sedan 6MT wrote:fbpem1: Try to be nice or
where was i not nice? i don't think i'm ever nice actually more tolerable so where was i not tolerable
Tampa G35 Sedan 6MT
I wish you wouldn't be such an angry tech! If I ever had a tech talk to me at an Infiniti dealer like you talk to people here I would have him fired! I just hope you are not like this at work... You would have no friends!
fbpem1
Tampa G35 Sedan 6MT wrote:I wish you wouldn't be such an angry tech! If I ever had a tech talk to me at an Infiniti dealer like you talk to people here I would have him fired! I just hope you are not like this at work... You would have no friends!
i have a strange feeling you keep reading emotion into my posts that just isn't there. I do notice that you only comment on what or how i say something when its directed at sbd can he not stick up for himself? *shrugs*
Sentientbydesign
96 I30 - Sold
I'm quite capable, but there are a few factors that stop me from "completely" expressing myself. One of them is that I do represent NICO and as such I don't make it a point to go off on members even though I could . I also find that sitting back shows who's the bigger person. Nothing implied here.
Point is, I'm not the only one who thinks you and your comments are brash. We aren't your drinking buddies that you've known for years. We're a bunch of strangers. Some of us are friends in person. Some of us are friend via the forums. Some of us respect that we don't like each other and try to keep our virtual "distance".
In any event, your contributions are only good if they are presented in a decent manner and have accurate information. Venting about how we sound just like the customers you hate is just going to ostracise you and you won't be welcome.
I hope you take that for it's face value and don't read into it or have some sardonic reply.
Tampa G35 Sedan 6MT
Let me set the record straight! I am one of the most heartless SOB you probably will never meet. I'm not reading any emotion into anything you have to contribute! I just don't like pompous a$$ comments. You come off as a Prick and for no reason! I guess that is why I work with people and with your tung I am glad you don't! I am sure SBD can stick up for himself as well as anyone else on NICO! I am the only one that calls you out on your mouth and tone!
DJ
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Sentientbydesign wrote:We aren't your drinking buddies that you've known for years. We're a bunch of strangers.
Exactly.
Ronnies points may be brash but he is pretty close. This is the main conscientious among the majority of non-forum participating techs do indeed feel this way. There are many guys out there who get out of bed solely to make money, but this is not limited to my profession.
This is a general note to all of you guys. If you suspect your clutch is on the way out. STOP "testing" it, that's going to generate a potentially catastrophic amount of friction that can damage the flywheel and pressure plate almost instantly. The clutch is not usually a warrantable part regardless of age mileage beyond the same 12/12 that the brakes are covered. I don't know of any manufacturer that would cover something like this. A clutch is not like an automatic where the driver cannot easily damage it and there are not really any parts inside the bellhousing to fail by factory defect.
G_whizz
Car: 2010 G37 Coupe Sport
Wow...I thought Canucky's were a sensitive bunch..
Everyone play nice...or else...or else...I'll ...I'll ask you to play nice again.
BTW...my Dad can beat up your Dads..
Jacko3
fbpem1 wrote:damnit my post was too long i guess, i lost a lot of it. Long and short of it is...vq's have a sprung hub clutch disc.
Fbpem1:
I agree with this assessment. After having a long discussion with my awesome Tech, he came to a similar conclusion. The dual mass flywheel of our Gs is only good for the comfort it provides. In fact, he said the dual mass flywheel is actually not so good for our transmission under spirited driving as the flywheel actually gets warped after a while and is not as stable as a regular flywheel. So, to reduce the distance the clutch has to travel if I have to dump it under spirited driving while increasing the sensitivity, we adjusted my clutch so that when i cluthc and dump, the clutch has very little distance to travel and thus less force on the flywheel. At least this is how I understood what he was saying. Like i said, we both take time to decide what needs to be done and how. He is the chief engineer and I am the driver.
Jacko3
I don't give a rats behind how, what, who, or when it is said. All I know is that I am learning a heck of a lot from everybody regardless of their experience and state in life. This thread is like school for me and I love learning. So, guys, keep the discussion coming along in any manner and way you deem fit. I am the one benefitting from it, as i am the one learning.
Jacko loves deep discussions as we have on this thread.
joe603
Thanks guys for the contribution to this thread. I'm sorry if a lot of it sounds like dealer bashing, but from the consumer's point of view, the dealer experience starts with a sales team that tries to capture every cent we have on a car. Personally, I HATE that game.
I'm not really upset over the extra $$ to fix my car; I'm upset because I believe that the problem was caused (or made worse) by a tech which is costing Nissan money....and since I own stock in the company, it costs' me money as well. I'm upset because this is the 4th or 5th time it's been to the dealer for a trans related issues...a new car should not be in the shop so many times IMO.
Anyway, the clutch should be here today...it will be a good mod once installed!
Tampa G35 Sedan 6MT
keep us posted because I might do the same when I have my trans done in December!
DJ
joe603
Will do!!
C-Kwik
fbpem1 wrote:dual mass are not resurfacable most you can do is hit with a wizz wheel but the springs inside are what is the worst of it
Good to know.
fbpem1 wrote:most dealers have a policy for customers they don't know dont have a relationship with the ASM must get checkout time or diag time or some sort of tear down time, i don't think its unreasonable to ask for a couple hundred bucks up front for just in case, your not paying the money now just approving it, i do that all the time and i will tell you this if said thing comes apart or whatever easy i wave the fee dosn't matter. Always have something up front, heres a ****ty analogy if you were to sell something to someone you don't know would it be ok to give them product let them try it out and they pay you tomorrow? no it wouldn't be authorization must be made for tear down work.
It's not unreasonable to inform a customer of potential charges. But the implication you made (perhaps unintentionally) was that the aftermarket parts were likely to break and that the customer should be charged for that regardless. No mention of the possibility that the charge would be waived was made by you.
fbpem1 wrote:i don't believe i made any assumption or lumped anyone into a catagory i was simply stating what could happen or what may happen or what might have happen, a d!ck way of playing devils advocate maybe...
It may not have been your intent. But that is how you came off. Particularly when you stated:
You already made a conclusion without all the facts. This is an assumption. And you did so based on the fact that he had a modification. Playing devil's advocate is fine. But given your occupation, it was largely self-serving in the way you presented it.
fbpem1 wrote:No i can't make a first hand diagnosis but i can base all my experiance with g and z trans issues into effect and from most i have pulled down with some sort of mods the clutch's have been in worse shape than the ones with more miles and no mods. Its a fact the car is driven harder your not going to put exhaust and whatever else on the car and then putt around like a grandma just dosn't happen your gonna open it up your going to have fun with it. Like i said though sometimes you gotta pay to play thats a fact of modifying anything.
On the other hand, when I had my G35, you would probably find that it would have looked much like or worse than many modified cars, despite the fact that I had absolutely no performance mods on it.
fbpem1 wrote:if you ahve looked at a motor that has bad OC on a vq which is needed the replacement motor smokes all the time, its not the rings trust me.
I have no idea what you are trying to say prior to the comma. Perhaps you can rewrite the sentence properly so that it makes sense.
However, while I don't disagree that it might not be the rings, I would ask you to eleborate. I don't simply trust anyone as a matter of experience or profession. I would actually like to hear an explanation or at least what you are observing as it wouldn't be much of a discussion if we were to just take your word for everything. Not that I ever would.
fbpem1
C-Kwik wrote:However, while I don't disagree that it might not be the rings, I would ask you to eleborate. I don't simply trust anyone as a matter of experience or profession. I would actually like to hear an explanation or at least what you are observing as it wouldn't be much of a discussion if we were to just take your word for everything. Not that I ever would.
That is actually proprietary information sir.
C-Kwik wrote:I have no idea what you are trying to say prior to the comma. Perhaps you can rewrite the sentence properly so that it makes sense.
is this better?
A VQ35 with the oil consumption issue smokes all the time not only on deceleration which would not be attributed to issue good old sbd stated.
Also everyone don't forget i'm a cunsumer as well maybe I'm different becuase i see it from the other side all day long and customers making stinks about things they really shouldn't and not taking any responsability for thier actions with the vehicle. So maybe i did jump to a conclusion maybe i didn't with Joe, but i still could be right =P i don't know no one does except him if he abuses the car. Personally i don't care i'll put a trans in it for him and probably not charge him for removing the aftermarket exhaust and only 1 labor hour to index the new flywheel and clutch install on top of no payment. Like me don't like me whatever, i'm good at what i do and i'm very fair someone can back me up on that i'm sure.
Jacko3 wrote:Fbpem1:
thats not a conclusion he came to its a fact =P, the acronym K.I.S.S. (keep it simple stupid) applies to everything when your "flogging" the car as you so sisentcly put it less moving parts = less sh*t to break. However i don't agree with the clutch adjustment.
Tampa G35 Sedan 6MT wrote:Let me set the record straight! I am one of the most heartless SOB you probably will never meet. I'm not reading any emotion into anything you have to contribute! I just don't like pompous a$$ comments. You come off as a Prick and for no reason! I guess that is why I work with people and with your tung I am glad you don't! I am sure SBD can stick up for himself as well as anyone else on NICO! I am the only one that calls you out on your mouth and tone!
I am saying your reading emotion into it because you don't know me and don't know how i am, pompous *** comments? sorry buddy I'm not pompous at all.
I do work with people actually i have an excellent relationship with ALL of my customers no matter who they are, good old Mr. Steve can vouch for that. I'm a nice guy you just DO NOT get me that's all.
Now for SBD, NO i DO NOT like him or what he does I'm sure that's been made clear time and time again, oh well can't like everyone. Although with what your doing I'm beginning to not like you as well reason being is your getting NOTHING from anything i post up here and if you look between those "pompous" comments there's a plethora of information there your looking right past that to a few things i have said. If you want to be that way fine whatever just don't respond at all go away no skin off of my back at all.
Joe, I mean all i ask is that people look on the other side of the fence with issues like these, I apologize for the customer bashing which wasn't really bashing just had a streak of "not my falters" one guy has had 3 transmissions, 2 motors, and now he blew his rear I'm done with it.
Also one more thing, for those who think my typing and spelling skills are sub par I type extremely fast and could care less about spelling spell check doesn't work here on my browser get over it
Modified by fbpem1 at 5:04 PM 12/5/2008
