Transmission Comparison RB25DET vs. VG30DETT.
stlthftr1
Car: 1978 280z with rb25det
Beatupsx wrote:The z32 transmission (vg30dett, vg30de) is the same internaly as the rb25.
all in all if anything went wrong with an rb25det transmission ...say throw out bearing , clutch , flywheel...... i could get vg30dett parts to replace them with????
DETurbine
Car: Nissan S13 RB25
Thrwnsprkz wrote:this thread is very helpfull, but i would like to know one thing, does anyone have any experience or know if the internals, (gears) from a vq30dett transmission could be transplanted into an rb25det transmission to rebuild it. My friends rb25 transmission just crap out on him and he was wondering this...any help with greatly appreicated
The gears and parts should all be the same, even the front shaft should be, but doubtfull that the rear shaft is the same from the looks of it.
It would be much cheaper and easier to just swap the RB25 bell housing onto a VG transmission rather then buying new or used parts for it. My 1st, 2nd, and 3rd syncro and gears needed to be replaced once I inspected it further....when it came down to replacing all the parts that needed it, ended up being around $900. Most of the gears on all pressed on there, so for all the time and money trying to make it work just to keep the rear housing, wasn't worth it at all to me. Easier switching bell housings and making a custom mount transmission mount. Also if it were to go out again, it is another cheap VG transmission and very little time dropping the transmission, switching bell housings, and then attaching it back on the motor.
That is just my opinion.
zdonner
Car: 1991 240SX SE Hatch
This question has been danced around in this thread so to ask it as directly as possible; will a RB26DETT Bell housing bolt up to a VG30DETT Transmission?
74260zt
Car: rb26powered early 74 260z car
zdonner wrote:This question has been danced around in this thread so to ask it as directly as possible; will a RB26DETT Bell housing bolt up to a VG30DETT Transmission?
YES!!! Here is a rb26 bell on a Z32 tail>>
click
Modified by 74260zt at 11:12 PM 3/4/2008
Racinjitter
Car: 1988 300ZX RB25DET
1988 300ZX Shiro Special
DETurbine wrote:I bet you could use the RB20 bellhousing on the Z31 transmission though.
Yea, but only the N/A z31. Not the turbo trannies. The 87-89 turbo transmission is identical to the rb25det transmission internally. The 84-86 turbo transmission is essentially a t-5. The n/a transmission is the same as a ka/sr/rb20 transmission internally.
USsil80
was thi a direct bolt on affair??
SIL-LINE
Car: S-13 With RB20det
Racinjitter wrote:
Yea, but only the N/A z31. The 84-86 turbo transmission is essentially a t-5. The n/a transmission is the same as a ka/sr/rb20 transmission internally.
so you mean that the 84-86 z31 n/a transmission is the same as an rb20 transmission ? if so , i can just find a transmission rebuild kit for that and just rebuild my 20 transmission ?
zdonner
Also is that the transmission setup you're using in your Z?
74260zt
Just swap the front bell... thats it. No, I'm using a complete rb25det trans in my Z.
zdonner
So then to clarify you have seen this RB26DETT mated to a Z32 gear box?
That is great news. Why has it taken so long to hear about this?
Shocker
Car: 89 240sxHB rb26/30
zdonner wrote:So then to clarify you have seen this RB26DETT mated to a Z32 gear box?
ummm Boostz has a whole right up on it on Hyridz.org
zdonner
I don't see anything there on the RB26 bell housing on a Z32 transmission, yeah I've known for years you can mate a Z32 to a RB25. I always suspected but never could confirm the RB26 would mate to the Z32 the same.
nyc240sx
Car: 1995 Nissan 240SX SE
RB25DET series 2
i have the rb26 bellhousing bolted up to the z32 n/a rear...rb25 and 26 bellhousing is the same.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
tell them to replace the transmission they sent you! if they dont call your credit card company or paypal n get ur money back (be sure to take a massive $hit through the shifter hole before you send it back though)
works every time!
WFreeman42
Car: 1990 300zx 2+2 N/A Automatic
Would all this information be the same if I was using auto trans?
Godoy pathfinderwd21
Car: Nissan pathfinder wd21 87
Hi friends, i have a nissan pathfinder1987 vg30i engine...
I wan t swap it to rb25 BUT, i don t know if i ll can use my gearbox :gotme :eekdance :help:
