sorry to say that your tranny in the picture is from a rb20det.Kansei240sx wrote:
thats exactly what i was talking about. all this tranny stuff makes me want to start reasearching how to mate a t56 up to a rb block. that would be the ultimate next to a 6 speed getrag.Yellow4g63 wrote:DET can't you just make the rails that attach the shifter longer like what Mozzy works dose on the there VG tran swap stuff?
if i am not mistaken there is a company that makes an adapter to mount up a chevy trns to the rb....Shocker wrote:
AWESOME! //sarcasm// so i have a mystery transmission..... There isnt anything RB20DET about my transmission...So it might be an N/A tranny. Im so confused on what to do right now.pirate87 wrote:There are two RB25 tranny's... the RB20DET/RB25DE tranny which was found mated to the RB20DET, but also to the RB25DE, and then there is the RB25DET exclusive tranny which wa only found on the RB25DET. The RB25 tranny's that you find for sale on ebay are probably RB20/RB25DE
here's the difference:
Yeah thats what I was thinking. They did somethng like that in a SCC mag for the VG engine swap into the 240sx. I'm not sure what month it was because I don't get them every month. So I would have to guess it was last months.DETurbine wrote:I am not sure what you mean by making the rails longer. Are you talking about the fork that mounts the rear shifter?. The only thing that you could do is maybe cut the fork that mounts the shifter about an inch and a half shorter and then you would have to cut and then reweld the shift linkage connection as well...but to much work to save an inch and a half. You dont want to be making anything longer like I said it is already sits back about 4 1/2 inches farther back then the RB did with the stock R33 crossmember. There is nothing confusing about it....you take your original RB25 bell housing and swap it bolt it up and might have to cut the transmission tunnel shifter hole a little. With mine it already sat up to far, so really it is just going to be back a few inches. Even 3 inches back from the stock location isnt a problem....doesnt make anything uncomfortable.
rb25 na manual tranny are the same as rb20. you're right, rb25det excluvisely have their own tranny, except the 4wd version.pirate87 wrote:There are two RB25 tranny's... the RB20DET/RB25DE tranny which was found mated to the RB20DET, but also to the RB25DE, and then there is the RB25DET exclusive tranny which wa only found on the RB25DET. The RB25 tranny's that you find for sale on ebay are probably RB20/RB25DE
If i have a hybrid z32 transmission, which part of that would be z32? All i can think of is the bellhousing becuase i had to modify the starter plate for my starter by cutting part of it out to get my starter on.. but then again, that doesnt even make sense becuase appearantly the bellhousings are different size, and the fact that i dont have weird shift linkage parts to deal with on my tranny, the thing sits in my car and i drove it untill it broke.BoostsFed wrote:rb25 na manual tranny are the same as rb20. you're right, rb25det excluvisely have their own tranny, except the 4wd version.
Kansei240sx, your tranny may be a z32 hybrid. it it works, then might as well keep it, otherwise tell venus to replace it.
hopefully that answers your question.DETurbine wrote:Since this has never been confirmed, becuase I am sure no one has actually done it, I have done the pleasure of doing it myself. This is a write up on the comparision of the RB25DET and VG30DETT transmissions and the swap itself.
First off here are the measurments of the two:
RB25DET:
Bell housing: 15 ½ inchesRear housing: 14 ¾ inchesShifter: 29 ¼ inches (from bell housing to middle of shifter).Middle case: 1 ¼ inches (where the bell housing and rear housing bolt onto).
VG30DETT
Bell housing: 16 inchesRear housing: 12 inchesShifter: 34 inches (from bell housing to middle of shifter).Middle case: 1 ¼ inches (where the bell housing and rear housing bolt onto).
Shifter position difference between the stock RB25DET and VG30DETT measured from the bell housing to the middle of the shifter hole is 4 ½ inches. VG being the longer one. ** keep in mind this is the RB25 bell housing on the VG transmission.
Driveshaft issues: Keep in mind for those that already have the RB25 in their car and have previously made the custom driveshaft to fit up to their original RB25 transmission and are now going with the VG transmission hybrid swap that you will have to modify the driveshaft since it is going to have to be about 2 ¼ inches shorter then the current driveshaft that you had made.
Now for those people that have said that even the bell housings will bolt up, that it 100% incorrect. They are different in many ways such as the starter natch out on the RB25 bell housing and the bolt holes themself are different.
The RB25DET bell housing will bolt straight up to the VG transmission without any problems. You can leave the rear VG caseing on, but like I had said above, the shifter itself will sit 4 1/2 inches farther back then the RB25 transmission. This wont be so bad for those with the stock R33 crossmember, since the shifter sits to far foward anyway. You are still going to hack up the transmission tunnel a little, but that just takes about 10 min.
For those that are asking why wouldn't you just get a RB25 transmission...well good luck finding one and when you do have fun spending the $1k plus. I bought my VG30DETT transmission for $150 with 30k miles on it and it takes about an hour to swap the bell housings around.
Hope this is a helpful write up....just figured it would be nice to have someone confirm it all.
