KaZ (VaBch) »
https://forums.nicoclub.com/kaz-vabch-u11666.html
Wed Jul 14, 2004 8:19 pm
A pressure tester is your friend...
You need a pressure valve, with male/female ends on each side, that you hook to a correctly sized PVC fitting, and put it in the intake hose where the MAF would be. You then hook the other side of the pressure valve to an Air Compressor and adjust the pressure valve to 10 PSI and listen for leaks... Works great.
I put a TTZ together for a guy that was running barely 6psi of boost (should have been more). Hooked up the pressure tester and found all sorts of leaks (hoses that had cracked on install, but that I couldn't see, clamps that were loose etc). Also if you're having trouble finding the leak, get something soapy, like windex or something, and spray around the questionable area and look for bubbles... works great.
What's required:
- PVC fitting correctly sized for your intake where the MAF connects (turbo side, not the intake side).- Adjustable air line pressure valve w/ pressure gauge (any gauge will work fine, you won't be going past 10psi with this setup anyway).- Male and Female air line adapters. You'll need the female end on the air compressor side, and the male end on the fitting side (or if you wanted to put a male fitting into the PVC fitting, put two females on the pressure valve, just make sure you hook it up in the right direction).- Air Compressor (anything will do, but holding constant 10psi will cause a average sized movable tank to RUN to keep the pressure up).
I've got this thing (5 Peak HP, 17 Gallon Husky Compressor creates 5.1 SCFM @ 90 psi. The compressor has a max pressure of 150 PSI and is perfect for the DIY'er) and at 8-10psi, I'll go from 120psi down to 60psi in a matter of minutes... and when the compressor kicks back on, its harder to hear the leaks. Thankfully I had a LONG hose setup, so I had the compressor around in front of the car I had sitting in front of the car I was working on (blocked some of the noise).
I can take some photos of my setup tonight for anyone interested.
Later,
