Transition From Vacuum to Boost
rico05
Car: 1992 RMS13 w/ CA18DET
Well, I went through almost an entire can of carb cleaner and nothing. Not a change at all in the motor. So while I wait for the head to cool a little, I pulled apard the MAF and cleaned it. It was a bit grunge in there so that may help. I'll keep you guys posted.
BTW, I ended up getting BCPR6ES-11S instead.
nab911
Car: 93 Nissan 240SX SE
Well if the car cleaner doesnt work then go for the leak tester. After i check today im gonna check some IC piping to look for oil and if i am blowing oil im going to whoop some as caus its a fresh turbo. But again im not running an oil restrictor and the smallest fitting is 1/8 OD.
rico05
Put it all back together and no real change. The plugs were a little funky, but I ahve seen worse (read rotary) Car revvs a little better and all, but nothing major. ECU is good, plugs are good, MAF is good, no major leaks...The only real thing that is weird about my car is the fact that there is no exhaust on the car....I am begenning to wonder if the no downpipe thing is my source of these worries....
Heavy Throttle needs to hurry up and get my damn gasket to me....:(
nab911
Shouldnt be, mine ran fine without it yesterday.
rico05
K. It is almost more of a problem of transition of light to hard throttle...
nab911
oh well then whatever leak you have (if its a leak) is something that is expanding with the sudden pressure change.. sound right? IM just guessin at this point
boost_boy
Quote »I think i may have fouled my plugs because im just running 18de plugs that autozone gave me so im not sure which of the 2 sets i got. If i get new plugs, what exactly should i ask for?[/quote] Not the best plug to be using!
Dee
NeedCAforS13
Car: CA swapped S13 coupe
I use 2 degree colder KA plugs IIRC...
Sean
nab911
im going to get the ones rico listed because they are probly fouled.
rico05
IF it is not a leak, what else could I check? What sensor or whatever would be the most likely? Time to bust out the FSM and the multimeter I guess....
boost_boy
Pour some water or spray some carburetor cleaner in between the #2 and #3 cylinder runners on the intake manifold portion that holds the butterfly valves. The key area of interest is the adjustment lever. When those seals go, it leaks all over the place and the only thing to do is change or completely remove the butterfly valves and seal the holes where the shafts extended through.
Dee
rico05
I sprayed carb cleaner all in there and no effect. I literally covered every inch of the head, intake plenum, TB, IC and piping, MAF, turbo intake side, intake area, intake tube with the stuff. Like I said, I went through a BIG can of the stuff this morning.
KaZ (VaBch)
Sorry this took so long... here are the shots of the setup.
PVC Pipe w/ Male Connector (connect this to the car)
Pressure valve setup. This is an "industrial" strength regulator... buddy of mine at work gave it to me. Goes way higher than necessary. Its set to 10PSI for those that can't see. You should NOT go any higher as you'll risk blowing oil seals!
To make your life easier, I'd recommend getting a couple extra male/female connectors and setting things up as you like. Normally, I've seen people put a female on the right side, and a male on the left. So then you can hook the air line from the compressor to the male (using the normal female connector on the hose) and then connect the female side to the male on the intake fitting. Hope this helps guys!
Xero
that's the same thing my KA is doing, and it's what is sending me to get my CA, yes guys, that's right, in ONE WEEK!!! I'm going to, most likely, be getting my CA18 front-cut. mwahahah!!!!
think it'll actually happen this time?
(to all the new guys, I'm like WAY old skool, hahah, so many new faces, even in 2 months, sheit)
boost_boy
Quote »think it'll actually happen this time?[/quote] Surprise us:D .
Dee
nab911
Other people sure have...
float_6969
I'm calling BS on Xero. He never delivers. He's like DiGiorno....
Xero
It's not delivery :rolleyes
float_6969
REALLY? You don't say? I did not know that. Hehehe.... thats the point I was making. Actually I wasn't making a point. Kinda just typing out some mindless banter....
Xero
I know, I got the joke, haha, you didn't :p
float_6969
Yea, I still think you look stupid. Hehehe, I'm going to hell...
Xero
yup, you are in fact going to hell,
Xero
Doode, I fixed my car yesterday, had that same buck and sputter and **** (see above)
on a whim, I pulled my O2 sensor and was surprised to hear rattling and ceramic sticking out of the inlet holes.
My O2 sensor 'sploded!!
so check that, I replaced mine with my spare and it runs like a champ again.
nab911
So no ca... so your now a DiGiorno guy....
hannibal
Car: Red Line to Glenmont
Rico, youre running w/o a downpipe? hows your O2 sensor hooked up??
