flinterman2000 »
https://forums.nicoclub.com/flinterman2000-u133168.html
Mon Mar 29, 2010 5:02 pm
Jack up the truck 14 to 18" off the ground. Slacken the bolts holding the transmission to the engine. Remove the starter and slacken and remove the torque converter bolts. Using a screw driver push the torque converter as far back as it can go. Place a jack under the transmission and remove the mountain bolts. Disconnect the selector rod and wires connected on the transmission. Lower the jack a little and shake side to side. The transmission should start sliding back. Make sure the torque converter is coming out with the transmission. Remove the transmission completely (you may need help to remove it). Remove the flex plate, then remove the shifter in the cab.
Install the flywheel, then install the clutch disc and pressure plate. Center the disc with the centering tool. Install the gearbox by lifting the rear over the cross member, then jacking up the front. With the input shaft of the box inline with the hole in the pressure plate push the box forward, rolling it side to side to line up the splines on the input shaft to those in the clutch disc. It should slide all the way up to the engine back plate. Install the bolts which hold the engine and box together. Jacking the back of the box, install the mounting and bolt in place. Tighten the bolts from the engine back. Install the clutch slave cylinder and drive shaft. Both trannies use the same yoke for the drive shaft. Attend to the wiring and you're done.
Hope this helps ya.
