DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Sep 12, 2005 8:05 pm
Did you replace the fluid? Do that first. You have to make an assumption about whether the transmission is the problem or whether there's an engine problem (possibly compounded by a transmission problem). An educated guess would be nice. If you assume the transmission is the only problem, then focus attention on the inhibitor switch and the vehicle speed sensor (VSS). These are the only 2 things in the transmission that can affect the running of the engine. I.e., if these are both fine, then I don't see why the engine would be rev-limited, unless the transmission is just plain fighting the engine for some reason. Check the inhibitor switch first with a multimeter using the characteristics in the FSM. I don't see how it could be the inhibitor switch. If that checks out, and since you're in the area, check the VSS continuity while spinning the tires (also in the FSM). Note that slow spinning may not reveal problems that show up under load--ideally you'd want to splice a probe into the wire and measure frequency while driving, but that would take some rigging.If there's an engine problem, then there are several other suspects. It could be fuel related, MAF related, or TPS related, among other things. You could have more than one problem, but work on one at a time. Measure fuel pressure, MAF voltage and TPS voltage, and compare values to FSM.
