So this is where yours is mounted? It would probably take removing the radiator to do it. I was kinda thinking that the air would be at the coolest at the bottom. Hmmmmm.qship96 wrote:it is getting a double heat treatment in that location! mounting it inbetween the condenser and radiator puts it BEFORE the heat load of the radiator!I would relocate it so it does not get the pre heated air!
Of course, I think it should have its own unheated flow of cool air, like the active cooler.elwesso wrote:i think the ideal location is on the bottom between the radiator and condensor...
It will after I install my main electric fan. I'm thinking about having it on an A/C-Temp replay with a manual overide switch so that I can turn it on at low speeds if necessary. I agree though, I think I'm gonna just pull the radiator and mount it in front of it. Thanks all!elwesso wrote:but it has no flow at low speeds which is where it needs it most.
Not unless it is holding in gear or going slowly up hill. More airflow than behind a raidator condenser with no fan acutuated! And more airflow when moving as there is no obstruction. Why the active cooler is located there.elwesso wrote:but it has no flow at low speeds which is where it needs it most.
With that in mind, seems the inlet and outlet of the ATF cooler would be perfect place to install the sensors.Q45tech wrote:Always a good idea with any add on heat exchanger to MEASURE the effects.
Yeah,elwesso wrote:i think the ideal location is on the bottom between the radiator and condensor...
Don't recall the LA to Vegas run frying Q45 transmissions?elwesso wrote:The only thing is that the trans doesnt need much cooling when its cruising at speeds.... At least thats how i understand it...
Does anyone have a photo of theirs mounted IN FRONT of the condensor then? It looks like a challenge at the very least to mount it there although it is obviously the best mounting spot.Q45tech wrote:Remember if the coolant is 180F and AC is on the air leaving the radiator is way over 160F.
In front of condenser ~~100-110F in traffic, after condenser 120-130-140F, after radiator 150-200F in traffic.
http://www.roscommonequipmentc...5.pdf
everything you need to know.
That may be ideal for the warm months but Ii'd be wary of having it that way in the winter. Might cause the transmission to run too cool.Flagship-Q wrote: Does anyone have a photo of theirs mounted IN FRONT of the condensor then? It looks like a challenge at the very least to mount it there although it is obviously the best mounting spot.
superuber wrote:This may be a dumb question, but what if you eliminate the transmission lines going to the rad and just run an external cooler. Is this bad or normal procedure?
Wes, my transmission coolers have been moved to the back of the car to clear up some space. They work fine back there. I have the trans. temp gauge to keep on eye on things. - Sijuelwesso wrote:Where do you have your cooler, siju?
