I think this is about twice what it should cost.. You should be able to get a clutch pedal for $50 shipped max..You don't need a brake pedal (just cut the one you have)Crossmember should be no more than $50 shipped max..Driveshaft should be no more than $50 shipped max.. .What fluid line?? clutch soft line? Get it at an auto parts store for under $10.MNVERT wrote:1 clutch pedal1brake pedal1crossmember w/ transmission mounts 1drive shaftfluid lines
-total $300
-I think you can keep the flywheel you already have. -New clutch is a good idea. -Master and slave cylander sound good. -Trans should be between $200 and $300 depending on shipping. -Clutch hardline can be bought from the nissan dealership for like $17. -You can get a used shifter really cheap.. but if you want a short shifter.. that's cool. -You don't need a new ECU.MNVERT wrote:***PARTS MISSING STILL***1clutch (NEW after market STAGE 2) $1501flywheel (NEW after market 11lbs. ) $1001 master and slave cylinder (NEW after market) $501 transmission $2001 clutch hardline (NEW after market) $301 shifter (NEW after market short shifter) and boot and plate(USED oem) $701ecu (USED OEM) $50
total of $$$550
Find that guy and I'll drive out there from DC and have him do another swap while he's at it. I'll even bring tools!Eikon wrote:I bet you could find a local NICO guy who would do it for $100 and a case of beer. Depending of course on having the proper tools for the job..
Very cool man!!!DjPantsSpecR wrote:i live right by the guy. if i pick up this vert maybe i'll swap mine and his at the same time for cheap...
i need to find that guy i got plenty of beers just not that much money..Eikon wrote:
As for labor... yeah.. probably a good 8 hours for book time.. at $75/hour. I bet you could find a local NICO guy who would do it for $100 and a case of beer. Depending of course on having the proper tools for the job..
That would be nice of you.DjPantsSpecR wrote:i live right by the guy. if i pick up this vert maybe i'll swap mine and his at the same time for cheap...
Dude.. "that guy" just posted above me.. DjPantsSpecRMNVERT wrote:i need to find that guy i got plenty of beers just not that much money..
i think it might of been called u pull r parts we have one in rosemount. the guy who posted 300 bucks dood give me your fone numebr i need this done right now do u have tools? can we do this from my house? the ****y part is that my garage is on a slope so i dont know if we would be able to put it on jack stands how lond does it take to do the swap?ishkabibble wrote:Yeah, Xenon lip. Thanks.
I lived all over the western suburbs, N and NE Mpls, and Midway. But I lived in BP first.
Man, it must be hard to find good condition 240s and parts in the Twin Cities. RWD is not that common and salt just eats the cars up. There used to be a huge you-pull-it junkyard that had imports - it was way out west off of Hwy 55, about a 50 minute drive. Can't remember the name, but it was a cool place because it was cheap and had a ton of really old cars. It's probably still around.
Go back and read my first post in the link I gave you.. about the transmissions.MNVERT wrote:no i havent what sensors are u talking about? pics please..
i unplug the sensor the one closest to the fuse box the first 1 nothing happened still wont go into gears the shifter goes into D reverse etc. but still no gear changes from the transmission . sighhhh.......DjPantsSpecR wrote:yeah, unplug that sensor, and drive it
have you tried that yet?
