Tsukiko »
https://forums.nicoclub.com/tsukiko-u52908.html
Wed Jun 27, 2012 3:50 pm
As an owner of an NA S5, don't bother unless this is going to be your weekend toy or track slut. They make horrible dailys unless you have a s*** ton of money to throw into them at any given time. Also, if you are planning on drifting it, there are limitations to consider.
-less steering angle stock
-front diff mounts need to be modded unless you wanna ruin it in short order and go through driveshafts like I did cause you can't really replace the U-joints.
-damn near 50/50 weight ration means they change direction VERY quickly. I STILL can't hold a drift after a transition. It just snaps around, no ifs ands or buts. This may be due to mine still having the stock DTSS bushings (dynamicly tuned steering system) in the back that create toe out under cornering g-forces. they get really old and sloppy over the years.
Bottom line, I would buy another. But I would make damn sure it has ALL the stock interior, and its all in pristine condition, and that there are no electrical issues. the grounding systems on these cars at their age need refreshing unless its already been done.
