Amen to that brother! I don't want any car that can park itself or Intellegent cruise control or any of that crap! Skilled drivers and less destractions is what the world needs more of.zozoka1212 wrote:
I don't know man. Car makers should go back to the drawing board and start fresh. Leave all these crap out of the car. Lets give the controll back to where it belongs the driver. Take the learning ECU and Drive by Wire and throw it in the garbage. Just give me a switch with 3-5 setting on it and let me pick the map for the ECU how I am going to drive next.
If it were ever to happen to me I would just press in the clutch & put it in neutral08.black.G37 wrote:I don't understand why somebody won't come out and tell people how to safely stop their vehicles! I'm sure Toyota won't, because that would be admitting guilt. I hear people talk about what to do and I just cringe! Hell no...you don't want to shut the car off when it is going 90mph (I didn't know a Prius would go that fast). Then you would have no power brakes or steering and your steering wheel would probably lock. Why won't somebody come out and instruct the public on how to safely stop their car, e.i. put it in nuetral and/or gear it down, blow up the POS, contact an attorney.....sue the crap out of Toyota.
That would be my procedure.
Is that the Nissan testing or just how I drive mine every single dayPoyzinous wrote:I dont know about dem toyoters, but nissan does some rigorous testing. They run their engines AT redline for a half hour in testing. When we do burnouts, thats a good 3 to 5 seconds of redlining. The time it takes to slow down from 60 or 80mph to a stop is all the motor would be revving to redline if you were to throw it into neutral. So no, no harm to your motor.
What he said...4wheelkillr wrote:Mr. Skeptic here: i don't believe the newest prius guy for a second. This happened within a week or so of going to the dealer for the problem and they said that car's not on the list. So he goes to a long empty highway and calls 911 and the news chopper comes out there and the CHP make it to him and catches up with him, pulls in front of him to help him stop and when he got below 50mph, THEN he shuts the car off...Give me a break. It sounds all staged to me.
My first thought was to call "shenanigans" on this but the trooper said he saw the brake lights on and smelt the pads burning. Like to see results of the analysis. I can't imagine anyone with half a brain doing this on purpose and expecting not to be discovered.kmckis1029 wrote:whats the point of faking the story though
Toyota would prefer you to press as lightly as possible on the brake pedal. To begin with, even regenerative braking is less efficient than coasting. There is a limit to how much current can be pushed into the battery. When you brake hard, you exceed this limit and the car is forced to use the friction brakes, too. However, nothing stops you from using the brakes like a racing driver approaching a slow corner at the end of a long straight.pwlorraine wrote:.... in normal operation the friction brakes aren't expected to be used until car speed is below 7mph.
