Tampa G35 Sedan 6MT wrote:would that be something good for my Jeep ... its an 89 with 105k miles?
DJ
I would try it. Do the 20% mix first, then you can try it a little higher if you want. I used it with the mobil Clean 5000 and Clean 7500. I wouldn't waste the money trying to mix it with any of the high end synthetics though.
BigMACKenzie wrote:I def used RP for my first oil change for teh vert, but it's $7.25 a quart retail in DC. I need to find out how to buy in bulk. I might be crazy, but I heard you are not supposed to use RP for an extended period of time/miles (over 3k) Did mom put acid in my orange juice again or amirite?
Here's some info which supports your non-acid-trip information. It might be biased since Amsoil did the testing, but it's still good info.
Amsoil wrote:As you may know, Royal Purple is well known in racing circles. The chemistry they use is something AMSOIL, Inc. chooses not to use in their oil formulation. One of Amsoil's big selling points is extended drain intervals, such as our 25,000 mile and 35,000 mile oil change intervals. Some additive chemicals such as Moly may cause adverse conditions when used for long periods.
Royal Purple uses a different chemistry than most oil producers. They are one of only a handful of marketers using Molybdenum Disulfide (Moly) in their oil formulations at these higher levels.
Moly is a processed mineral that is similar in appearance to graphite. Moly has good lubricating properties when used either by itself (in dry power form or as an additive to oil or other lubricants). Particles of the Moly can come out of suspension and agglomerate. Over time this may actually clog or partially clog oil filters or oil lines and the remainder normally settles in the bottom of the oil pan. This seems to be more likely when using extended drain intervals. The only test we ran on Royal Purple involved their 20W50 Racing oil versus our AMSOIL Series 2000 Synthetic 20W50 Racing Oil (TRO). We ran two 4 ball wear tests with different parameters, a spectrographic baseline, FTIR scan and volatility tests. The Royal Purple showed a significantly high volatility rate with a 12.51% boil off rate. This compares to the AMSOIL TRO with only a 4.47% volatility rating. Wear scars were also smaller with the TRO. For example the AMSOIL TRO left a .41mm scar and the Royal Purple oil left a .66mm scar. The lower the scar damage number the better! There was also a surprising difference in the viscosity index. The RP has a VI of 129 versus 155 for the TRO. The higher the VI, the better the viscosity stays in place at high temperatures.
Note: This information was provided by AMSOIL, Inc. Tech Department. An independent lab tested the Royal Purple 20W-50 racing oil against the AMSOIL 20W-50 racing oil. The results are posted above. Test results found Moly in the Royal Purple oil sample.
To elaborate on Smocker's information. Many synthetics use mineral base stocks an attempt to break the molecules down through numerous methods until they have smaller "uniform" molecules which they can reconstruct. This is analogous to making cake batter and trying to extract the eggs (not the greatest analogy, but it makes the point).
The issue in doing this is that, you don't have a person splitting each and every molecule. You have a process breaking down huge vats of base stock. Another issue is that the base stock oil is not all comprised of the same molecules. Variations will occur and those molecules will break down differently when subjected to the same processes. What you end up with is inconsistencies. These inconsistencies are dealt with by using additives.
These additives only provide temporary fixes because sooner or later, they won't be able to keep the oil stable and it will break down.
Pure Synthetics are chemically engineered in a more consistent manner.
Something I just read that's interesting. Wikipedia cites that API Group III Oils (Hydrocracked or Hydroisomerized-The ones that are processed to death) are only allowed to be sold as "Synthetics" in the US. Has anybody else found this information eleswhere?
Jacko,
Why don't you just spend the $20-$40 on an oil analysis at the end of 3k miles to see how the oil is. Then you won't have to wait for God to come tap on your shoulder and tell you you're wasting oil.
