Thursday wrote:sounds like there is more of a chance of breaking rings with these gapless rings.
From the factory, the 2nd ring end-gap is larger than the first to allow blow by instead of the compression getting stuck between the two compression rings and possibly reverting upward. If the second compression end gap is larger than the first then compression can travel downward easily. This is somewhat theoretical but I believe if rings without a gap are better in every way then the OEM manufacturers would be using them as they generally use high quality components.
They are significantly more expensive and both Child's and Albert and Total Seal carry patents. So they would either have to be purchased from them, or royalties paid to them. But you are thinking, and that is good. Normally speaking, I agree with your logic about the OEMs, but I think we can all name at least one example of a superior product that is not used by the OEMs due to cost restraints over the entire line. These are better rings, but OEMs are satisfactory, and much less expensive, that is why they do not get used.
Further, on the Nissan KA24DE piston your compression rings are identically sized at 1.5mm and the oil control ring is 2.8mm. So it is inconsequential the placement of the rings, except that one will be a scraper ring, and one will not, since the head of the piston is slightly smaller than the skirt.
Finally, I am speaking purely in the theoretical, since I am having issues with excessive blow-by, I can almost certainly trace it to a worn cyl or worn rings. In either case, I know that my end gap is either out of spec or close to it. Since the rings are somewhat sprung, I know that as rings or cyl's wear, the ring will project itself outward and close the gap. This will cause the overall ring end gap to increase. So, if I have worn rings, or worn cyl's, I SHOULD be able to use a gapless ring to achieve a more consistant compression across cyl, without overboring (which I will not be doing, if this engine comes out, an SR is going in). Unless my cyl's are egg shaped (elliptical wear pattern), which is unlikely given the previous wear theory, the Total seal rings should work.
Would you not agree?
BTW, I want to clarify that this is in no way a flame, just a civilized debate.
