sxseguy »
https://forums.nicoclub.com/sxseguy-u5378.html
Thu Mar 15, 2007 2:37 am
Some additional info for everyone:
You can get them at good old summit.com. Search for TSR-M0664 (gapless top ring sets - $175) or TSR-T0664 (gapless second ring sets - $137). They come in standard, +.020 and +.040 sizes.
Gapless top sets (includes gapless top rings, conventional middle rings, and stainless oil rings)
Gapless second sets (includes conventional top rings, gapless middle rings, and stainless oil rings)
But... the Wiseco pistons use 1.0, 1.2, 2.8 mm rings instead of the standard Nissan thickness of 1.5, 1.5, 2.8 mm. So, the standard KA rings won't work with these and some other aftermarket pistons.
Maybe other piston owners can confirm ring thicknesses for their pistons. I know the Ross uses non-standard ring thicknesses. Anyhow, I did some more research and found other sets that might work.
Gapless top set for +.5mm overbore, 1.0, 1.2 2.8 mm ring set - $49 (single piston set, four required, so $196)
Gapless 2nd set for +.5mm overbore, 1.0, 1.2 2.8 mm ring set - $136 (full set of four)
I still have to confirm that these will work. I'm not sure of the groove depth and ring depth matching yet. These particular rings are listed for a Honda XR500 motorcycle, but the dimensions check out so far.
