Man it has excellent compression but runs horrible.
I have checked and double checked the timing at the marks on the upper/lower chain.
I have checked the distributor and the rotor is lined up at #1 at TDC #1.
I have swapped the distributor
It sounds like a vacuum leak.
I think its the lifters. I dropped it off at the machine shop to get shaved with the lifters installed. I went to remove them and the owner was like its cool leave them in and I'll take care of it. I got it back and four of the lifter shims did not have oil passages drilled in them any longer? I tried using the lifters and shims from a 2001 head and it would not run at all.
Should I use the cams from the car I pulled the head from and see if it runs?
below is a video please click listen and suggest
