Well, your honda friends know roughly d!ck about cars (unsurprisingly so...). I've never seen an intake or exhaust system reduce torque compared to stock by any meaningful amount. Generally there are gains everywhere. Torque-wise, yes it does have a lot compared to other I4s. An integra LS for example, has about 110 ft-lbs of torque. The KA24DE has 160ft-lbs of torque. This is largely due to the larger displacement, but also due to the longer stroke and long intake runners (and secondary butterflies, if you have an S13).240crawler wrote:This may sound stupid, but is the ka24de really a torque monster? My 240 is the first N/A 4 cyl that I have really driven. I have had a turbo Integra that I bought already boosted, and I know that the high strung motor was not a good reflection of I4 power. My friend drove me home from the club last night, and was impressed with the power of my car. He never revved past 3500, and wanted to know if it was inline or v6. I told him it was a 2.4 I4, and he opened the hood in disbelief. He said that for a 4 cyl, it had alot of torque. Can you tell me if the 240 is really that much stouter bottom end than other 4's. I am curious, because I am disappointed in the power output of my car. He offered to let me drive his corolla when I sobered up to compare. He said that his car is dead below 5000rpm. I would like more top end, but I am afraid to intake and exhaust because my Honda friends(not many) say it will kill all bottom end. Help!!!
The second one is also blatantly wrong.s1ndicate wrote:TheOne, the quotes in your sig are awesome.
Is that true, i know someone who said he could hook it up with a full exhaust system, but the only thing was it would be flowmaster. Was deciding on 2.5 but since you said 3" gains on n/a, im just curious if this is true...All_Motor_KA wrote:Intake and exhaust is ALWAYS a good thing no matter what. The KA is one of the few inline four cylinder non turbo motors to make more torque then horsepower. Intake, header and full exhaust and you will experience how the KA was meant to be. And the KA is one of the few engines that make horsepower off a 3'' exhaust when non turbo. I believe it is one of the best 4 cylinders ever made.
3" gains quite a lot on NA actually. THere's 2 legit dynos floating around of a 13 and 15whp gain from just a 3" exhaust.TheExaltedS14K wrote:Is that true, i know someone who said he could hook it up with a full exhaust system, but the only thing was it would be flowmaster. Was deciding on 2.5 but since you said 3" gains on n/a, im just curious if this is true...
What about a Dodge Viper that weighed 1400 lbs.InsanityInc wrote:
The first is also fairly wrong. A dodge viper isn't going to beat a moden F1 car.
A modern F1 car is a pure race car designed for one thing, and one thing only, raceing. You can not compare it to a a car that was designed to perform well on the street. Besides, horsepower equals torque multiplied by RPM devided by 5252. So torque really does win races .InsanityInc wrote:The second one is also blatantly wrong.
Hm, so you mean car design wins races, not torque? Why, that's preposterous and certainly Mr. Shelby would disagree with you.All_Motor_KA wrote:A modern F1 car is a pure race car designed for one thing, and one thing only, raceing. You can not compare it to a a car that was designed to perform well on the street. Besides, horsepower equals torque multiplied by RPM devided by 5252. So torque really does win races .
It would win before that. F1 cars have 300-400 horsepower on a viper. Also, my money would be on the F1 car to 60, simply because the F1 driver probably wouldn't need to shift out of first gear to get to 60.TheOne™ wrote:actually, if the viper weighted the same as the F1, the viper would be able to win from a stand to maybe 60mph.(then the F1 would pass it cause of its higher rpm and better gear ratios, believe an F1 does more than 60mph in first gear)
You're right , but you really can't compare a $5000 engine to a $200,000 engine. Anyway an F1 is tuned for optimal everything so if you changed the gearing it probably run slower. Also the new F1 engines are getting so much more efficient that they are almost just as fast if not faster than the old turbo cars.InsanityInc wrote: The turbo ones were far, far faster (so fast they banned turbos because too many drivers were dying). The fastest all motor honda drag car is 11s, if I recall.
The old turbo cars were making well over 1000 horsepower. Even the best NA engines in F1 are still a few hundred behind. Also, changing the gearing would make it run faster in the quarter mile as you could design the gearing to be as short as possible to allow it to just reach it's trap speed at redline in top gear. F1 cars have to be geared fairly wide to reach speeds of 200+, whereas they could be geared shorter if they were only being run for a 1/4 mile, where their trap speed probably wouldn't exceed 150.D-UNIT wrote:You're right , but you really can't compare a $5000 engine to a $200,000 engine. Anyway an F1 is tuned for optimal everything so if you changed the gearing it probably run slower. Also the new F1 engines are getting so much more efficient that they are almost just as fast if not faster than the old turbo cars.
It is, relatively speaking. It's obviously not a 427.Loveless wrote:torque monster? according to my butt dyno, it sucks
